I am studying Electrical Engineering and I came across one definition of the volt being defined as follows:
V = J / C
Where "V" is voltage measured in "volts", "J" is energy measured in "joules" and "C" is charge measured in "coulombs". If this definition is correct, it would appear that a 10 V battery should be able to produce 10 joules of energy per coulomb of charge. My question is, what is the relationship between volts and Mechanical Energy?
The reason I bring this up, is because if we assume that the acceleration due to gravity is 10 m/s², the amount of energy required to move 1 kg of water a distance of 1 meter vertically is equivalent to 10 joules. I used the following formula:
F = m * a = (1 kg) * (10 m/s²) = 10 newtons.
W = F * d = (10 N) * (1 m) = 10 joules.
Does this mean that using a 10 V battery, I should be able to create a device that is able to move 1 kg of water a distance of 1 meter up in the air? I am trying to better understand the relationship of volts as a difference in Electrical Potential between two points in space and somehow using this potential to move objects with a certain mass a certain distance. Perhaps I am mixing different physics concepts together. Any insight into this would be appreciated. Cheers.
