-1
I simulated two circuits as shown below.
  1. The body terminal is shorted to source terminal and the resulting source voltage is 5V.
  1. The body terminal is shorted to ground and Vs = 1V (Vg - Vth). I can't understand the reason behind this.
Also in the second case, why should Vov be zero. Why can't Vs be equal to Vg?
Thanks
  • \$\begingroup\$ If the source is floating, the only current can come from the drain-source leakage and the body diode leakage. \$\endgroup\$ – τεκ Jan 25 '18 at 5:17
  • \$\begingroup\$ Yes, the body current is almost zero. So is the drain current. Since the source is floating the current could be 1 femtoampere and the source would still be at 1V. \$\endgroup\$ – τεκ Jan 25 '18 at 5:22
  • \$\begingroup\$ Why can't Vs be equal to Vg? Why should Vs and Vg be equal? what makes you think they should? I mean, they're not connected in any way. \$\endgroup\$ – Bimpelrekkie Jan 25 '18 at 6:48
Q: What is the voltage at node x?
A: depends on the channel leakage of the MOSFET and the leakage current of the diode.
    \$\begingroup\$ Although this does explain what happens to the source voltage, this isn't exactly the same situation as OP is asking. If you put 3 V DC at the gate using a Vdc then it would be identical. Then at x you'd get Vs = 3 V - Vt due to the source-bulk diode's leakage current. \$\endgroup\$ – Bimpelrekkie Jan 25 '18 at 6:46
