I have a benchtop power supply (it's not in front of me right now, so I can't say the model, sorry) and it has a current limiting mode enabling it to operate as a current source. However, it also has an "over-voltage" and "over-current" protection mode (OVP and OCP, respectively). Once either OVP or OCP trip, the supply stops providing any power.
My question is: why do those protection modes exist if I can just set the limits on current and voltage myself? Presumably, if I know what to set the protection modes to I'll know what to set the limits to, so what's the point?
  • \$\begingroup\$ No. It turns out I can just google image search and find it :-P It's a Keysight U8002A \$\endgroup\$ Commented Jan 25, 2018 at 11:45
  • \$\begingroup\$ In some situations you want it to behave one way, in some the other. \$\endgroup\$
    – PlasmaHH
    Commented Jan 25, 2018 at 11:48
  • \$\begingroup\$ I can imagine, yes. What might an example be of a situation in which CC mode is insufficient? \$\endgroup\$ Commented Jan 25, 2018 at 11:50
  • \$\begingroup\$ OCP might be operating on the input supply feed? \$\endgroup\$
    Commented Jan 25, 2018 at 11:51
    \$\begingroup\$ @MichaelStachowsky: I would probably not enable it if possible, or set it to somewhat higher. \$\endgroup\$
    – PlasmaHH
    Commented Jan 25, 2018 at 11:56
With a bench power supply you also have to take account for what the thing is attached to.
The CC circuit may be set to say 3A, but if the circuit is back-feeding, or through-feeding 5A the CC won't protect you.
Same goes for voltage, You may set the adjuster to hold 12V but if the output is shorted to 24V you want the bench power supply to let go.
  • OVP - OverVoltage Protection: When OVP function is turned on, if the output voltage is higher than protection setup value, the output cuts off - ie. goes to 0V.
  • CC - Constant Current mode: When the power supply is in constant current mode, it will limit the output to voltage that gives the setup current value through the load.
  • OCP - OverCurrent Protection: When over current function is turned on, if the output current is higher than protection setup value, the output cuts off - ie. goes to 0V.
  • \$\begingroup\$ is CC same as "limiter"? \$\endgroup\$
    – johny why
    Commented May 24, 2022 at 13:16
