I have instantiated a block RAM module using Block Memory Generator segment of the Xilinx IP Core. Alternatively, I have coded my own simple single-port RAM module, much like on page 33 of these lecture slides (http://www-inst.eecs.berkeley.edu/~cs150/fa11/agenda/lec/lec10-sram1.pdf).
With each clock tick, I'm constantly updating the address and simultaneously writing to that block of my RAM module. Like this:
reg [5:0] address;
initial address = 6'b0;
always @(posedge clk)
begin
    address <= address + 1'b1;
end
block_ram uut (
    .clk(clk),
    .write_en(write_en),
    .address(address),
    .datain(datain),
    .dataout(dataout)
After populating the appropriate RAM addresses, what I would like to do is read back specific addresses and concatenate them together to make one larger wire, like so:
wire [624:0] concatenated_ram;
assign concatenated_ram = {ram[0], ram[1], ram[2], ram[3], ...}
The only way I can conceptualize this is by assigning the singular 'dataout' port of my RAM to a different wire depending on the address:
always @(*)
begin
    case (address)
        0: dataout1 <= dataout_from_RAM;
        1: dataout2 <= dataout_from_RAM;
        2: dataout3 <= dataout_from_RAM;
    endcase
end
Can anyone think of other options? Using a case statement to grab the data doesn't seem that efficient to me.
Thanks for any assistance in advance!!
  • 6
    \$\begingroup\$ We may give you advice if you tell us what is the purpose of this exercise and what do you want to get as a result. Having 625 wire bus does not seem to be good idea, given there will probably be not so many pins for I/O this bus out of the chip. \$\endgroup\$
    – Anonymous
    Jan 25, 2018 at 14:55
    \$\begingroup\$ Your description would be easier to follow if you didn't change context for each code block. + why? \$\endgroup\$ Jan 25, 2018 at 15:48
I figured this out. I didn't really need block RAM at all for my purposes.
To describe the purpose of this exercise (for those interested), I am trying to send data from a text file through a serial communication to an FPGA. Every time the serial connection signals there is data to be sent, the FPGA logic should accept data and write it to an appropriate location. Basically, this amounts to a register file:
reg [15:0] RAM [0:63];  // 64 x 16-bit (128 byte) RAM
reg [5:0] addr;         // 6-bit addressing to 64 elements
begin
    if (write_data_flag == 1'b1)
    begin
        RAM[addr] <= data_from_USB;
        addr <= addr + 1'b1;
    end
end
When synthesized, this results in distributed RAM (implemented as an LUT), which eats into the available resources I have for synthesizing other logic. Since my RAM array is rather small, I think this is OK.
