I am currently working on the USB hub part for a multiport USB-RS232-converter. The current design is for Terminus Tech's FE 2.1 Hub IC. Regarding the impedance of USB signal traces the layout guidelines state:
DP, DM Differential trace impedance = [DP(45ohm) + DM(45ohm)] = 90 ohm, and do not jump the DP DM signals that cause impedance miss match
To meet those requirements I used some online impedance calculators to estimate the required trace properties for a 2-layer FR4 PCB. However, the results I got are not consistent at all:
- Hughes Circuits
- input values
- trace thickness: 1 oz/ft^2
- substrate height: 1.6 mm
- trace width: 1 mm
- trace spacing: 0.15 mm
- substrate dielectric 4.5
- results
- odd impedance: 45.5 ohms
- even impedance: 119 ohms
- common impedance: 59.3 ohms
- differential impedance: 90.9 ohms
- input values
- Montaro
- input values
- trace width: 3.35 mm
- trace separation: 10 mm
- trace thickness: 0.03556 mm
- dielectric thickness: 1.6 mm
- relative dielectric constant: 4.5
- results
- differential impedance: 90.035 ohms
- single ended impedance: 45.071 ohms
- input values
- All About Circuits
- input values
- trace width: 4.15 mm
- trace spacing: 14.8 mm
- results
- odd impedance: 45.0 ohms
- even impedance: 36.8 ohms
- common impedance: 18.4 ohms
- differential impedance: 90.0 ohms
- input values
- Colorado Electronic Product Design
- input values for single microstrip
- w: 3.5
- h: 1.6
- t: 0.03556
- epsilon: 4.5
- result for single microstrip
- impedance: 45.12 Ohms
- input values for microstrip pair
- s: 15
- h: 1.6
- Z_0: 45.12 Ohms
- result for microstrip pair
- Z_d: 90.23 Ohms
- EEWeb
- input values
- trace width: 4 mm
- trace spacing: 5.5 mm
- substrate dielectric: 4.5
- results
- even impedance: 38.7 ohms
- common impedance: 19.4 ohms
- differential impedance: 90.1 ohms
- input values
In addition to those calculation I found some other resources with some sample trace properties:
- Mikrocontroller.net Forum
- trace width: 0.22 mm
- trace distance: 0.13 mm
- substrate thickness 1.6 mm
- resulting differential impedance: 100 Ohms
- IBEX
- 1.6 mm PCB
- 1.48 mm FR4 thickness to GND plane
- 35 um copper trace thickness
- trace spacing 0.15 mm
- trace width 1.12 mm
- resulting differential impedance: 90.184 Ohms
Why do those results differ that much? Since I am a beginner in doing impedance controlled PCB design I do not know which resource to trust. Any hints about dependable trace properties for designing USB on a 2-layer FR4 board are pretty much appreciated.
