Currently working on a design project for school where a display is needed.
I need help figuring out what parts I need to split the 10 wire ribbon cable that comes of the LCD into 10 jumper cable to go into a breadboard for testing.
The closest thing I found was this https://www.mouser.com/ProductDetail/710-68711014022 But I will still need to connect jumper cables to that as well
LCD being used :https://www.mouser.com/ProductDetail/?qs=La0%252b8xZSm19d3Mbp4mkNrQ%3d%3d
LCD data sheet: https://www.mouser.com/ds/2/365/LS013B7DH03%20SPEC_SMA-1203020.pdf
closed as unclear what you're asking by laptop2d, PeterJ, Sparky256, uint128_t, Whit3rd Feb 2 '18 at 6:00
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
It's quite clear from the datasheet what connector is mating the one on the display. Did you read it through? Page 9 of the pdf:
enter image description here Page 25 of the pdf:
Using the appropriate FPC/FFC connector that corresponds to these two suggestions, you could make a small breakout board yourself that you can mount the connector to, and have pin headers to put in your breadboard if you're so inclined.
If you don't want to make it yourself, you can get FPC/FFC adapter boards from Proto Advantage
