I am using nested for loops using generate module for creating multiple instances of sub-modules in verilog this is for finding 4x4 determinant. I generated the sub-modules with inputs given accordingly but I want store outputs in array register serially from (1 to 6) as it runs 6 iterations in tempu[1:6] and tempd[1:6] but generate is not allowing to do so. I tried all the possibilities
    module det_4x4_v2(
         input signed [15:0] a11,a12,a13,a14,a21,a22,a23,a24,a31,a32,a33,a34,a41,a42,a43,a44,
         output signed [15:0] out
     wire signed [15:0]  v1[1:4];
     wire signed [15:0]  v2[1:4];
     wire signed [15:0]  v3[1:4];
     wire signed [15:0]  v4[1:4];
     wire signed [15:0] tempu[1:6];
     wire signed [15:0] tempd[1:6];
    assign v1[1]=a11;
    assign v1[2]=a12;
    assign v1[3]=a13;
    assign v1[4]=a14;
    assign v2[1]=a21;
    assign v2[2]=a22;
    assign v2[3]=a23;
    assign v2[4]=a24;
    assign v3[1]=a31;
    assign v3[2]=a32;
    assign v3[3]=a33;
    assign v3[4]=a34;
    assign v4[1]=a41;
    assign v4[2]=a42;
    assign v4[3]=a43;
    assign v4[4]=a44;
    genvar i,j,count;
    generate
       //localparam count=0;
      //for(count=1;count<7;count=count+1)
    for(j=1;j<4;j=j+1)
    begin:gen_det2x2_sub1
     for(i=j+1;i<5;i=i+1)
         begin:gen_det2x2_sub2
         det_2x2 m1(v1[j],v1[i],v2[j],v2[i],tempu[count+1]);
         det_2x2 m2(v3[j],v3[i],v4[j],v4[i],tempd[count+1]);
         end
    end
    endgenerate
assign out = ((tempu[1]*tempd[6])-(tempu[2]*tempd[5])+(tempu[3]*tempd[4])+
              (tempu[4]*tempd[3])-(tempu[5]*tempd[2])+(tempu[6]*tempd[1]));
                            // above equation want to implement-------(1)
    endmodule
/*    det_2x2 m1(v1[1],v1[2],v2[1],v2[2],tempu[1]);  //finally want to generate
      det_2x2 m1(v1[1],v1[3],v2[1],v2[3],tempu[2]);   // these modules
      det_2x2 m1(v1[1],v1[4],v2[1],v2[4],tempu[3]);
      det_2x2 m1(v1[2],v1[3],v2[2],v2[3],tempu[4]);
      det_2x2 m1(v1[2],v1[4],v2[2],v2[4],tempu[5]);
      det_2x2 m1(v1[3],v1[4],v2[3],v2[4],tempu[6]);
      det_2x2 m2(v3[j],v3[i],v4[j],v4[i],tempd[count]); // same way as above m1
        module
module det_2x2(
 input signed [15:0] a11,a12,a21,a22 ,
 wire signed [15:0] temp;
 assign temp = (a11*a22)-(a12*a21);
 assign out = temp ;
endmodule
the sign of each term in equation 1 depends on (-1)power(i+j) in each iteration and should me multiplied with `tempu or tempd' in the particular iteration.
i can implement these manually (instatiate manually and write out equation (1) manually) but its difficult when doing for higher order matrices where for (8x8) it takes 70 modules for instantiation.
please help me in assigning the temp,tempd registers continuously indexed for the above nested loops.
thank you
  • \$\begingroup\$ Can you explain what you mean by "I want store outputs in array register serially" Perhaps you can show how you want the generate to be expanded into individual instances \$\endgroup\$
    – dave_59
    Jan 27, 2018 at 19:42
  • \$\begingroup\$ yeah definitely i added them \$\endgroup\$
    – chago
    Jan 28, 2018 at 2:32
    \$\begingroup\$ Why is there commented out code? That doesn't help us and just confuses things. \$\endgroup\$ Jan 28, 2018 at 2:39
You can't use a 'free' generate variable 'count' thus the only solution I can come up with is to express the index of tempu and tempd in terms of i and j. This is how your j,i go:
[j,i] = [1,2] [1,3], [1,4]   required Index:  1, 2, 3
        [2,3] [2,4]                           4, 5
        [3,4]                                 6
The best I can come up with is:
det_2x2 m1(v1[j],v1[i],v2[j],v2[i],tempu[ j==1? i-1 : j==2 ? i+1 : 6]);
det_2x2 m2(v3[j],v3[i],v4[j],v4[i],tempd[ j==1? i-1 : j==2 ? i+1 : 6]);
But it is clumsy and very specific to this code. As soon as the upper limit of the for loop changes that is no longer valid.
It passes a quick syntax check in Vivado, but can't fully check it because I have no det_2x2.
  • \$\begingroup\$ i updated my code with submodules . \$\endgroup\$
    – chago
    Jan 28, 2018 at 2:34
