I have an MPU-9150 which uses I2C address 0x68 by default, but I'd like it to use address 0x69. This is possible by desoldering the 3-way AD0 "Jumper" on the breakout board. By default there are 3 solder pads and pads 2+3 are connected, so that pin AD0 is defaulting to "ground".
So as I understand it, I need to "desolder" the connection from pads 2+3 and then I can connect VCC to pin AD0 which will switch the I2C address to 0x69.
I tried desoldering, but it looks like this won't "break" the connection even if I get rid of all the solder. It looks like it'll still be connected due to the little "circle" and the edges around it (see images). I haven't done such tiny connections before yet either - so any tips on how to best proceed ?
Also, I'd like to understand better how this 3-way jumper works. So assuming pads 2+3 are desoldered, can I "manually regulate" which address is going to be used by putting "high" or "low" on pin AD0 (or is it then going to be fixed to 0x69)? ... and not connecting anything to the pin now would probably be "bad"?
What happens if I'd solder AD0 jumper pads 1+2 together?
Will it then always be using the higher I2C address (0x69)?
For future reference: Following the suggestions of SamGibson, cutting the connection between pads 2+3 using a hobbyknife + loupe - and then connecting 3.3V to AD0, it now indeed reports I2C address 0x69, see image :
