I have an Apple iPhone front and rear cameras along with its A4 motherboard (yep, I disassembled it) is it possible that I can get a live feed from these camera(s) to a display and connected to a power source? or maybe storing the recorded thing on a memory drive? I could not find the exact terms so the searches were not relevant. (images for reference attached)
Camera pieces
closed as too broad by pipe, DoxyLover, Voltage Spike, Finbarr, Lior Bilia Feb 22 '18 at 16:02
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ I suspect the only way you'll get anything usable out of these cameras is with a working iPhone. \$\endgroup\$ – Finbarr Jan 29 '18 at 15:25
  • \$\begingroup\$ @Finbarr so I won't be able to use these cameras somewhere else? \$\endgroup\$ – PlopMon Jan 30 '18 at 11:14
  • \$\begingroup\$ Unless you can get documentation on how to use the cameras, which I doubt, you would need to use specialised equipment and a lot of time and knowledge to figure that out for yourself, then design and program your own circuits to talk to them with no support available from anyone. Good luck! \$\endgroup\$ – Finbarr Jan 30 '18 at 15:40
  • \$\begingroup\$ @Finbarr so should I post another question on 'how to create a simple circuit sending camera footage to a display?' since your comment solved my question \$\endgroup\$ – PlopMon Feb 2 '18 at 13:24
  • \$\begingroup\$ That question would almost certainly be closed as too broad. What is it you're trying to achieve exactly? \$\endgroup\$ – Finbarr Feb 2 '18 at 13:39
After understanding @Finbarr 's comments:
And also that:
A smartphone will have a microprocessor, interface chips and lots of software in the middle
It seems that my requirement cannot be fulfilled according to the way I wanted to.
