For a larger project where I basically want to boost phone signals indoors using an external antenna I have devised a small experiment to make sure I get the basics right before I expend a lot of energy.
Basically, I have made an enclosure to reduce signal strength in which I put a cell phone displaying the current RSSI or dBm and a small-scale version of the external and internal antenna setup. Basically just two small antennas connected by a wire.
The idea was that I should be able to measure a difference in signal strength inside of the box when putting a small antenna connected to another antenna outside of the box. This would then validate the feasability of using the bigger antennas.
The setup
Step 1 was to make an enclosure that would block (some) signals. A card board box wrapped in aluminium foil was no true Faraday cage, but when closing the lid it managed to reduce the signal strength by 15dB, which is noticable.
Signal reducing enclosure works Enclosure to reduce signal strength
Step 2 was then to verify that these antennas would boost the signal inside of the box. This is where I fail, somehow. While closing the lid of the box made the signal go from -90 to -105 on the dBm scale, putting the antenna in there made absolutely no difference - no matter how long I waited.
I suddenly realized that I might be reading the wrong figures, as I still had 4G enabled (the antennas are both for about 900 MHz, while 4G is 1800 and 2100 MHz in Norway), but disabling 4G and strictly running on 2G made no real difference.
So this leaves me wondering: what am I doing wrong? Are there some basic assumptions I have made on how this should work that are just plain wrong?
Debugging steps:
  • I have verified that there's no short in any of the links from the black whip up until the N-connector using a voltmeter (0.6 V reading).
  • I have turned off 4G
  • I have verified that I lose 12-15dB of signal when closing the lid
  • Tech specs on the long whip (900 MHz range)
  • Tech specs on the stick antenna (900 MHz range)
  • The splitter box used to connect the two male cable connectors seems to be fine too when checking using a voltmeter.
  • \$\begingroup\$ A passive re-radiator requires a very short cable. Attenuation in the cable can be substantial. \$\endgroup\$
    – user57037
    Commented Jan 29, 2018 at 23:53
  • \$\begingroup\$ I understand that, but we are talking about a mere 3m of cable. Even with a flimsy cable like pictured, that's usually not more than handful of dB at such a short length. Surely it should show some improvement in the signal reading? \$\endgroup\$
    – oligofren
    Commented Jan 29, 2018 at 23:59
    \$\begingroup\$ @AliChen, that's incorrect. Those are active devices. This concerns passive amplification. Basically you would put one of those where my signal splitter is. Problem is that active GSM amplification is illegal in Norway for anyone that's not a phone company, as it will disturb reception for everyone else. Thus passive amplification using a high gain antenna is usually your only bet. \$\endgroup\$
    – oligofren
    Commented Jan 30, 2018 at 5:16
    \$\begingroup\$ The splitter is for sure going to cost you several dB. Probably over 3.5dB. Think about it. It splits power. Also, what is the impedance seen looking in from the "big" antenna side when one of the splitter ports is open circuit? So the unterminated splitter could possibly be creating a mismatch. To give this a chance, I would definitely try to find a very short cable and do a direct connection with no splitter. \$\endgroup\$
    – user57037
    Commented Jan 31, 2018 at 1:55
    \$\begingroup\$ @mkeith That's a good point. Thanks for that! For this experiment I just needed the splitter to connect the two male SMA connectors from each antenna. I'll see if I can find a connector with female in both ends. \$\endgroup\$
    – oligofren
    Commented Jan 31, 2018 at 12:27
The large antenna is collecting a portion of the cell tower's energy which falls within its "antenna aperture". Your system is then radiating this energy from the small antenna in all directions.
(Not really, of course, but you see the point).
Only a small amount of this power is being re-radiated in the direction of the cell phone's antenna.
I expect you could detect the improvement in signal strength if your chamber had a higher level of attenuation. But as it is it's getting swamped out by the direct signal which is coming from the cell tower.
  • \$\begingroup\$ Thanks, that makes sense. Given that the external antenna receives 1W of power, only 1W/x, where x is some integer, will reach the cell phone. Making x smaller by directing the energy in one direction would then probably give better results. Too bad smartphones can't be directly connected by cable: that would make x closer to 1, I assume. \$\endgroup\$
    – oligofren
    Commented Jan 30, 2018 at 5:27
