This question already has an answer here:
This power supply is used for LED strip lights I recently purchased. I want to know if the dimmer below can be used with the power supply. The PS is AC 100-240v (IN) to DC 12v (OUT), while the dimmer is DC 12-24v (IN/OUT), based on my intuition, this should work.
marked as duplicate by Olin Lathrop power-supply Feb 2 '18 at 12:13
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
    \$\begingroup\$ looks ok........ \$\endgroup\$ – Sunnyskyguy EE75 Feb 1 '18 at 0:01
  • \$\begingroup\$ THe Dimmer that is.... but are you sure LEDs take 50W? \$\endgroup\$ – Sunnyskyguy EE75 Feb 1 '18 at 0:44
  • \$\begingroup\$ The power supply is included with the LED lights kit, so I'm not concerned about it not working, my concern was the dimmer because it's generic and made by a different manufacturer. \$\endgroup\$ – raffian Feb 1 '18 at 0:53
  • \$\begingroup\$ OK then its less than 24W which sounds right for a 5m reel. no problem on dimmer. \$\endgroup\$ – Sunnyskyguy EE75 Feb 1 '18 at 1:02
  • \$\begingroup\$ Tony, does it matter how the wires from the power supply connect to the dimmer IN input? \$\endgroup\$ – raffian Feb 1 '18 at 1:30
As long as you have looked at the power (in W) and made sure the dimmer can handle it, it should be fine.
If there is a 12V supply and the dimmer states 12-24V, then you should have no issues. Just double check wiring!
  • \$\begingroup\$ Thanks, just a quick follow up, the dimmer above is PWM, but they also offer a non-PWM version, what's the difference? \$\endgroup\$ – raffian Feb 2 '18 at 16:01
  • \$\begingroup\$ You would have to look at the datasheets to find that out and compare them! \$\endgroup\$ – Curious Feb 7 '18 at 12:48
