As a school project I want to write a very simple controller for a flash memory in a IC board. The FPGA chip is Altera 5CEFA4F23C8 and the flash is MX25L3206E.
I did an effort to produce the SCLK, SI and other signals that the chip needs through verilog, respecting the timing etc. I conceived the controller as a finite state machine that suppose to generate the SPI signals in order.
I have loaded the system to the board but it is not receiving anything from SO as I thought it would do automatically.
I'm using a "testbench-like" module that produce the avalon control, address and data signals like write, read and address, for a future implementation on a larger Avalon communication protocol SoC.
I'm adding the code I write for your reference.
    module FLASH_CTL (
 ////////////// avalon interface///////////////////
    input   wire [23:0] avalon_slave_address,
    input   wire [3:0]  avalon_slave_byteenable,
    input   wire        avalon_slave_read,          //             .read
    input   wire        avalon_slave_write,         //             .write
    input   wire [31:0] avalon_slave_writedata,     //             .writedata
    input   wire        reset_sink_reset,           //   reset_sink.reset
    input   wire        clock_sink_clk,             // clock_sink_1.clk
    output wire [31:0]  avalon_slave_readdata,      //             .readdata
    output wire avalon_slave_readdatavalid, //             .readdatavalid
    output wire avalon_slave_waitrequest,   //             .waitrequest
//////////////// chip interface ///////////////////
    input wire SO,
    output reg SI,
    output reg CS,
    output wire WP,
    output wire HOLD,
    output reg SCLK
parameter ST_0 = 4'd0; parameter ST_1 = 4'd1; parameter ST_2 = 4'd2; parameter ST_3 = 4'd3;
parameter ST_4 = 4'd4; parameter ST_5 = 4'd5; parameter ST_6 = 4'd6; parameter ST_7 = 4'd7;
parameter ST_8 = 4'd8; parameter ST_9 = 4'd9; parameter ST_10 = 4'd10; parameter ST_11 = 4'd11;
parameter wr_comm = 8'b0000_0010; // PROGRAM  0X02, write 0000_0010
parameter rd_comm = 8'b0000_0011; // PROGRAM  0X03, read 0000_0011
parameter test_A = 8'b0001_1111;
reg [7:0] test_reg;
always@ (posedge  clock_sink_clk or negedge reset_sink_reset) begin
    if (~reset_sink_reset)
        test_reg <= 0;
    else
        test_reg <= test_A;
end
reg [31:0] av_wrdata;
reg f_cyc_count, enable, rd_SO, f_bit_count, wr_mode, word_ak, clear_byte_c;
reg av_rd7, av_rd6, av_rd5, av_rd4, av_rd3, av_rd2, av_rd1, av_rd0;
reg [3:0] state, nextstate;
reg [4:0] cyc_count, byte_count;
reg [7:0] comm_in, data_in, av_rd_byte1, av_rd_byte2, av_rd_byte3, av_rd_byte4;
reg [23:0] addr_in;
reg [4:0] bit_count;
wire [7:0] av_rd_buff;
reg [2:0] bytes_enabled;
wire burstcount, debugaccess;
assign WP = 1;
assign HOLD = 1;
assign avalon_slave_waitrequest = ~ CS;
assign avalon_slave_readdatavalid = (CS && state >= 1 && wr_mode)? 1'b1:1'b0;
assign avalon_slave_readdata = {av_rd_byte1, av_rd_byte2, av_rd_byte3, av_rd_byte4};
assign av_rd_buff = {av_rd7, av_rd6, av_rd5, av_rd4, av_rd3, av_rd2, av_rd1, av_rd0};
assign burstcount = 0;
assign debugaccess = 0;
always@ (posedge  clock_sink_clk or negedge reset_sink_reset)begin
    bytes_enabled <= 1;
else begin
    bytes_enabled <= bytes_enabled;
    case (avalon_slave_byteenable)
        4'b0001:    bytes_enabled <= 3'd0;
        4'b0011:    bytes_enabled <= 3'd1;
        4'b0111:    bytes_enabled <= 3'd2;
        4'b1111:    bytes_enabled <= 3'd3;
        default:    bytes_enabled <= bytes_enabled;
    endcase
end
end
    state <= ST_0;
else
    state <= nextstate;
always@ (*) begin
CS <= 0; SI <= 0; SCLK <= 0; f_bit_count <= 0; f_cyc_count <= 0; rd_SO <= 0; word_ak <= 0; clear_byte_c <= 0;
case (state)
ST_0:   begin
            if (enable) begin
            nextstate <= ST_1;
            CS <= 0;
            end
            else begin
            nextstate <= ST_0;
            CS <= 1;
            end
        end
ST_1:   begin
            SI <= 0;  // dont care
            SCLK <= 1;
            if (cyc_count == 10) begin
                    f_cyc_count <= 0;
                    nextstate <= ST_2;
            end
            else begin
                    f_cyc_count <= 1;
                    nextstate <= ST_1;
            end
        end
ST_2:   begin                                       ///// send command
            SI <= comm_in [7 - bit_count];
            SCLK <= 0;
                    f_cyc_count <= 0;
                    nextstate <= ST_3;
            end
            else begin
                    f_cyc_count <= 1;
                    nextstate <= ST_2;
            end
        end
ST_3:   begin
            SCLK <= 1;
                f_cyc_count <= 0;
                f_bit_count <= 1;
                if (bit_count == 7) begin
                    nextstate <= ST_4;
                    word_ak <= 1;
                    clear_byte_c <= 1;
                end
                else begin
                    clear_byte_c <= 0;
                    nextstate = ST_2;
                    word_ak <= 0;
                end
            end
            else begin
                word_ak <= 0;
                f_bit_count <= 0;
                f_cyc_count <= 1;
                nextstate <= ST_3;
            end
        end
ST_4:   begin                                           ///// send address
            SI <= addr_in [23 - bit_count];
            SCLK <= 0;
            f_bit_count <= 0;
                    f_cyc_count <= 0;
                    nextstate <= ST_5;
            end
            else begin
                    f_cyc_count <= 1;
                    nextstate <= ST_4;
            end
        end
ST_5:   begin
            SCLK <= 1;
                f_cyc_count <= 0;
                f_bit_count <= 1;
                if (bit_count == 23) begin
                    word_ak <= 1;
                    clear_byte_c <= 1;
                    if (wr_mode)
                    nextstate = ST_6;
                    else
                    nextstate = ST_9;
                end
                else begin
                    clear_byte_c <= 0;
                    nextstate = ST_4;
                    word_ak <= 0;
                end
            end
            else begin
                    word_ak <= 0;
                    f_cyc_count <= 1;
                    nextstate <= ST_5;
            end
        end
ST_6:   begin                                   /// write
            SI <= data_in [7 - bit_count];
            SCLK <= 0;
            f_bit_count <= 0;
                f_cyc_count <= 0;
                nextstate <= ST_7;
            end
            else begin
                f_cyc_count <= 1;
                nextstate <= ST_6;
            end
        end
ST_7:   begin
            SCLK <= 1;
                f_cyc_count <= 0;
                f_bit_count <= 1;
                    word_ak <= 1;
                    if (byte_count == bytes_enabled) begin
                        clear_byte_c <= 1;
                        nextstate <= ST_8;
                    end
                    else begin
                        clear_byte_c <= 0;
                        nextstate <= ST_6;
                    end
                end
                else begin
                    clear_byte_c <= 0;
                    word_ak <= 0;
                    nextstate = ST_6;
                end
            end
            else begin
                clear_byte_c <= 0;
                word_ak <= 0;
                f_bit_count <= 0;
                f_cyc_count <= 1;
                nextstate <= ST_7;
            end
        end
ST_8:   begin
            rd_SO <= 0;
            CS <= 1;
                    f_cyc_count <= 0;
                    nextstate <= ST_0;
            end
            else begin
                    f_cyc_count <= 1;
                    nextstate <= ST_8;
            end
        end
ST_9:   begin
            rd_SO <= 0;                     // read
            SI <= 0;
            SCLK <= 0;
            f_bit_count <= 0;
                    f_cyc_count <= 0;
                    nextstate <= ST_10;
            end
            else begin
                    f_cyc_count <= 1;
                    nextstate <= ST_9;
            end
        end
ST_10:  begin
            rd_SO <= 1;
            SCLK <= 1;
                f_cyc_count <= 0;
                f_bit_count <= 1;
                    word_ak <= 1;
                        clear_byte_c <= 1;
                        nextstate <= ST_11;
                    end
                    else begin
                        clear_byte_c <= 0;
                        nextstate <= ST_9;
                    end
                end
                else begin
                    clear_byte_c <= 0;
                    word_ak <= 0;
                    nextstate = ST_9;
                end
            end
            else begin
                clear_byte_c <= 0;
                word_ak <= 0;
                f_bit_count <= 0;
                f_cyc_count <= 1;
                nextstate <= ST_10;
            end
        end
ST_11:  begin
            rd_SO <= 0;
            CS <= 1;
                    f_cyc_count <= 0;
                    nextstate <= ST_0;
            end
            else begin
                    f_cyc_count <= 1;
                    nextstate <= ST_11;
            end
        end
default: begin
            CS <= 0; SI <= 0; SCLK <= 0; f_bit_count <= 0; f_cyc_count <= 0; nextstate <= ST_0;
            rd_SO <= 0; clear_byte_c <= 0;
         end
endcase
end
always@(posedge  clock_sink_clk or negedge reset_sink_reset)    begin
    if (~reset_sink_reset) begin
        av_rd7 <= 0; av_rd6 <= 0; av_rd5 <= 0; av_rd4 <= 0;
        av_rd3 <= 0;av_rd2 <= 0;av_rd1 <= 0;av_rd0 <= 0;
    end
    else if (rd_SO) begin
        av_rd7 <= av_rd7; av_rd6 <= av_rd6; av_rd5 <= av_rd5; av_rd4 <= av_rd4;
        av_rd3 <= av_rd3; av_rd2 <= av_rd2; av_rd1 <= av_rd1; av_rd0 <= av_rd0;
        case (bit_count)
            0:  av_rd7 <= SO;
            1:  av_rd6 <= SO;
            2:  av_rd5 <= SO;
            3:  av_rd4 <= SO;
            4:  av_rd3 <= SO;
            5:  av_rd2 <= SO;
            6:  av_rd1 <= SO;
            7:  av_rd0 <= SO;
            default: begin
                    end
        endcase
    end
    else if (CS && state >= 1) begin
    end
    else begin
    end
end
always@(posedge  clock_sink_clk or negedge reset_sink_reset) begin      // DESASOCIAR BIT_COUNT DE CYCLE COUNTER
        bit_count <= 0;
    else if (word_ak)
        bit_count <= 0;
    else if (f_bit_count)
        bit_count <= bit_count + 4'b1;
    else
        bit_count <= bit_count;
end
        cyc_count <= 0;
    else if (f_cyc_count)
        cyc_count <= cyc_count + 4'b1;
    else
        cyc_count <= 0;
end
        byte_count <= 0;
        byte_count <= 0;
    else if (clear_byte_c)
        byte_count <= 0;
    else if (word_ak)
        byte_count <= byte_count + 4'b1;
    else
        byte_count <= byte_count;
end
//////////////// Controls enable from write and read /////////////////////
        enable <= 0;
    else if (avalon_slave_write || avalon_slave_read)
        enable <= 1;
    else
        enable <= 0;
end
////// controls write vs read order, with priority write /////////////////
        wr_mode <= 0;
    else if (avalon_slave_write)
        wr_mode <= 1;
        wr_mode <= 0;
    else
        wr_mode <= wr_mode;
end
        comm_in <= rd_comm;
        comm_in <= wr_comm;
    else if (avalon_slave_read)
        comm_in <= rd_comm;
    else
        comm_in <= comm_in;
end
        addr_in <= 0;
    else if (avalon_slave_write || avalon_slave_read )
        addr_in <= avalon_slave_address;
    else
        addr_in <= addr_in;
end
        av_wrdata <= 0;
        av_wrdata <= avalon_slave_writedata;
    else
        av_wrdata <= av_wrdata;
end
        data_in <= avalon_slave_writedata [7:0];
    else
    case (byte_count)
        0:  data_in <= av_wrdata [7:0];
        1:  data_in <= av_wrdata[15:8];
        2:  data_in <= av_wrdata [23:16];
        3:  data_in <= av_wrdata [31:24];
        default: data_in <= av_wrdata [7:0];
    endcase
end
///////// Gather all 4 bytes in 1 register ////////////////////////
        av_rd_byte1 <= 0; av_rd_byte2 <= 0; av_rd_byte3 <= 0; av_rd_byte4 <= 0;
    end
    else if (clear_byte_c && state >= ST_10) begin
        av_rd_byte1 <= av_rd_byte1; av_rd_byte2 <= av_rd_byte2; av_rd_byte3 <= av_rd_byte3; av_rd_byte4 <= av_rd_byte4;
        case (byte_count)
            0:  av_rd_byte1 <= av_rd_buff;
            1:  av_rd_byte2 <= av_rd_buff;
            2:  av_rd_byte3 <= av_rd_buff;
            3:  av_rd_byte4 <= av_rd_buff;
            default: begin
                    end
        endcase
    end
    end
end
endmodule
The top module is this
        module FLASH_CTL_TOP (
        input   wire    sys_rst,           //   reset_sink.reset
        input   wire    sys_clk,             // clock_sink_1.clk
        input wire SO,
        output wire SI,
        output wire CS,
        output wire WP,
        output wire HOLD,
        output wire SCLK ,
        output reg led
        reg [23:0]  avalon_slave_address;// avalon_slave.address    ?????????????????????????
        reg [3:0]   avalon_slave_byteenable;    //             .byteenable
        reg avalon_slave_read;          //             .read
        reg avalon_slave_write;         //             .write
        reg [31:0]  avalon_slave_writedata;     //             .writedata
        reg [14:0] tb_count;
        wire [31:0] avalon_slave_readdata;      //             .readdata
        wire avalon_slave_readdatavalid; //             .readdatavalid
        wire avalon_slave_waitrequest;   //             .waitrequest
        wire debugaccess, burstcount;
        reg [31:0] led_counter;
    flash_qsys u0  (
        .clk_clk             (sys_clk),             //   clk.clk
        .reset_reset_n       (sys_rst),       // reset.reset_n
        .end_cs              (CS),              //   end.cs
        .end_si              (SI),              //      .si
        .end_so              (SO),              //      .so
        .end_wp              (WP),              //      .wp
        .end_sclk            (SCLK),            //      .sclk
        .end_hold            (HOLD),            //      .hold
        .sobus_waitrequest   (avalon_slave_waitrequest),   // sobus.waitrequest
        .sobus_readdata      (avalon_slave_readdata),      //      .readdata
        .sobus_readdatavalid (avalon_slave_readdatavalid), //      .readdatavalid
        .sobus_burstcount    (burstcount),    //      .burstcount
        .sobus_writedata     (avalon_slave_writedata),     //      .writedata
        .sobus_address       (avalon_slave_address),       //      .address
        .sobus_write         (avalon_slave_write),         //      .write
        .sobus_read          (avalon_slave_read),          //      .read
        .sobus_byteenable    (avalon_slave_byteenable),    //      .byteenable
        .sobus_debugaccess   (debugaccess)    //      .debugaccess
FLASH_CTL FLASH_CTL_inst1 (
.SO (SO),
.SI (SI),
.CS(CS),
.WP(WP),
.HOLD(HOLD),
.SCLK(SCLK),
.avalon_slave_address (avalon_slave_address),
.avalon_slave_byteenable (avalon_slave_byteenable),
.avalon_slave_read (avalon_slave_read),
.avalon_slave_write (avalon_slave_write ),
.avalon_slave_writedata (avalon_slave_writedata),
.reset_sink_reset (sys_rst),
.clock_sink_clk (sys_clk),
.avalon_slave_readdata (avalon_slave_readdata),
.avalon_slave_readdatavalid (avalon_slave_readdatavalid),
.avalon_slave_waitrequest (avalon_slave_waitrequest)
always@(posedge sys_clk or negedge sys_rst) begin
    if (~sys_rst) begin
        led <= 1;
        led_counter <= 0;
    end
    else if (led_counter == 31'd100_000_000) begin
        led <= 0;
        led_counter <= led_counter + 16'b1;;
    end
    else if (led_counter == 31'd200_000_000) begin
        led <= 1;
        led_counter <= 0;
    end
    else begin
        led <= led;
    end
end
    if (~sys_rst) begin
        avalon_slave_read <= 0;
        avalon_slave_write <= 0;
        avalon_slave_address <= 0;
        avalon_slave_writedata <= 0;
        avalon_slave_byteenable <= 0;
    end
    else if (tb_count == 200) begin
        avalon_slave_write <= 1;
        avalon_slave_address <= 24'b0000_0000_0000_0000_0000_0011;  //// 24'b0000_0000_0000_0000_0000_0011
        avalon_slave_writedata <= 32'b1010_1010_1010_0000__0000_0000_0000_0011; //8'b1000_0101
        avalon_slave_byteenable <= 4'b1111;
    end
    else if (tb_count == 2000) begin
        avalon_slave_read <= 1;
        avalon_slave_writedata <= 32'b0000_0000_0000_0000__0000_0000_0000_0000; // 8'b0000_0000
    end
    else begin
    end
end
always@ (posedge sys_clk or negedge sys_rst) begin
    if (~sys_rst)
        tb_count <= 0;
    else if (tb_count == 3000)
        tb_count <= tb_count;
    else
        tb_count <= tb_count + 15'b1;
end
endmodule
The code is basically running as expected (as far as I know) as it can be seen in the second attached imag, but I'm receiving this "1" from the SO pin from the beginning of the time without changes, so I'm not able to pick up the "supposedly" data from SO.
any thoughts about this? Chip might be malfunctioning?
  • \$\begingroup\$ You need to ask a specific question. \$\endgroup\$
    – TimB
    Feb 1, 2018 at 7:50
  • \$\begingroup\$ @TimB thanks, what would you suggest? I need to know what's wrong with the code, why is not working? I don't have idea how to translate this question into the rules of the website. \$\endgroup\$
    – user176257
    Feb 1, 2018 at 8:03
    \$\begingroup\$ You have put up over 650 lines of Verilog code and that is without the test bench. You can't expect us to just 'check' that. You also say that it is not outputting anything from SO but SO is an input. \$\endgroup\$
    – Oldfart
    Feb 1, 2018 at 8:11
  • \$\begingroup\$ @oldfart I meant to say outputting from chip (to the FPGA), I'm inputting signals to the chip, but not receiving the outputted response from the chip. \$\endgroup\$
    – user176257
    Feb 1, 2018 at 8:55
  • \$\begingroup\$ I suggest debugging and asking a specific question. We are not here to debug your problems. The site is for asking specific questions relevant to all, and receiving well written answers that can be useful for others. You neither have a specific question, nor a question which an answer could be used to help someone in the future. Instead you have phrased a “please fix my code” request in the form of a question. \$\endgroup\$
    – TimB
    Feb 1, 2018 at 8:55
I wonder why your trace doesn't have SI signaling? A SPI Flash memory is not a simple device, it needs status checking and likely some mode selection commands to start operating. Where is CS# in your traces? What is HOLD# status? From datasheet:
DEVICE OPERATION
1.Before a command is issued, status register should be checked to ensure device is ready for the intended operation.
2.When incorrect command is inputted to this device, it enters standby mode and remains in standby mode until next CS# falling edge. In standby mode, SO pin of the device is High-Z. The CS# falling time needs to follow tCHCL spec.
3.When correct command is inputted to this device, it enters active mode and remains in active mode until next CS# rising edge. The CS# rising time needs to follow tCLCH spec.
4.Input data is latched on the rising edge of Serial Clock(SCLK) and data is shifted out on the falling edge of SCLK. The difference of Serial mode 0 and mode 3 is shown in Figure 1.
5.For the following instructions: RDID, RDSR, RDSCUR, READ, FAST_READ, RDSFDP, DREAD, RES, and REMS the shifted-in instruction sequence is followed by a data-out sequence. After any bit of data being shifted out, the CS# can be high. For the following instructions: WREN, WRDI, WRSR, SE, BE, CE, PP, RDP, DP, ENSO, EXSO, and WRSCUR, the CS# must go high exactly at the byte boundary; otherwise, the instruction will be rejected and not executed.
6.While a Write Status Register, Program, or Erase operation is in progress, access to the memory array is neglected and will not affect the current operation of Write Status Register, Program, Erase
Which command are you sending to your memory chip?
  • \$\begingroup\$ Sorry I did not included the SI and CS signals in the picture of the wave, I'm updating those pictures now. I'm sending the WRITE ENABLE (06h) and the WRITE COMMAND (02H). The problem is that chip does not seems to care any command I send, since start up is outputting "1". I'm thinking it is on stand by mode but WRITE ENABLE should take it out from it, but there is nothing that make it change. So I might be doing something wrong. \$\endgroup\$
    – user176257
    Feb 5, 2018 at 1:46
  • \$\begingroup\$ @user176257 Does any of your sequential CS#-CLK-SI data resemble timing diagrams shown in Figures 7 - etc. etc. of the IC datasheet? macronix.com/Lists/Datasheet/Attachments/6665/… \$\endgroup\$ Feb 5, 2018 at 2:15
  • \$\begingroup\$ I tried to send the CS, CLK and SI signal as described in the Datasheet, even taking care of the timming, altough I don't know if I do it correctly. The last attached image I'm sending 9Fh command for reading chip ID. Nothing comeout from the SO except 1 perpetually. You can observe also that reset is a routed to a button in the board I'm working, the reset is naturally 0, then I press become 1 but because the time is very short, signal tap ii screening shows it still at 1 and starting the FSM. \$\endgroup\$
    – user176257
    Feb 6, 2018 at 7:30
  • \$\begingroup\$ @user176257, "even taking care of the timming" sounds like a dangerous sloppiness. I think you violate timing for assertion of CS# relative to CLK, see Figure 7. More, max READ speed is 33 MHz, while your clock seems to be 45 MHz (22 ns). Take a second read of datasheets. You are still not plotting HOLD# and WP# signals. We are not interested in your state machine internals, only the real output is important to the issue. \$\endgroup\$ Feb 6, 2018 at 17:39
    \$\begingroup\$ I finally made the chip to talk back to me with the command 05h, I was making a mistake indeed with the timming SCLK is half period forward than it should, I fixed it and at least I know the chip is working good. Thank you. I wish to select your answer as best but I'm new, I'll do it once I can. \$\endgroup\$
    – user176257
    Feb 7, 2018 at 8:22
