Let's say we have the following circuit:
The known values are: \$\beta=100\$, \$Vcc=2.5V\$, \$V_A=\infty\$ (meaning the Early effect is not taken into account), \$V_{BE}=0.7V\$, \$I_S=8\cdot10^{-16}A\$ (which is the reverse saturation current of the base–emitter junction), \$Rc=1k\Omega\$, \$R_E=400\Omega\$, \$R_1=13k\Omega\$, \$R_2=12k\Omega\$.
If we assume that the transistor is opperating in active mode, and the Early effect is not taken into account, we can calculate the collector current by:
$$I_C=I_S\cdot e^\frac{V_{BE}}{V_T}$$
where \$V_T\$ is the thermal voltage of approximately \$26mV\$.
All the values are known and we get:
$$I_C\approx0.394mA$$
However, let's say we won't use that formula and we won't assume the transistor is in active mode. We can find the Thevenin equivalent of the base voltage as:
$$Et=\frac{R_2}{R_1+R_2}Vcc=1.2V$$
$$Rt=R_1||R_2=6.24k\Omega$$
Now the equivalent circuit looks like this:
If we apply the second Kirchhoff law to the left contour, we get:
$$Et-Rt\cdot I_B-V_{BE}-Re\cdot I_E=0$$ Since \$I_B=\frac{I_C}{\beta}\$ and \$I_E=\frac{\beta+1}{\beta}I_C\$, we get:
$$Et-Rt\frac{I_C}{\beta}-V_{BE}-Re \frac{\beta+1}{\beta}I_C=0$$ $$I_C=\beta\frac{Et-V_{BE}}{Rt+Re(1+\beta)}\approx 1.07mA$$
As we can see, we get different results. Where did I make a mistake in my calculations?
