In a typical clocking circuit configuration, where a crystal is tied at the input to an amplifier such as is shown below:
The capacitance required for \$C_1\$ and \$C_2\$ would be based on the load capacitance equation (sorry, not sure how to format equations on SE):
$$C_L = \frac{C_{1}\times C_{2}}{C_{1}+C_{2}}+C_S$$
However, what happens when you use an oscillator... such as the ACH-25.000MHZ-EK?
There is nothing in the application notes about needing a capacitor, so do I actually need one? (and for oscillators in general?) I am thinking that because this is still an oscillating circuit, similar to the crystal (clock configuration circuit)... That I will still need some sort of capacitor to keep the oscillator stable. Or am I wrong, and do I not need to attach any capacitor(s) to either the output or GND pins?
