After 40+ years you would think I would know this, somehow it never came up, but for the life of me I don't see it.
Typical transistors specs list a plethora of values but one that always seems to be missing is \$I_{b_{MAX}}\$. That is, the maximum current you can pass through the base emitter junction.
Obviously you can't exceed the power rating across the base-emitter diode forward drop, so 626mW/0.7V ~ 900mA, but I have a feeling there is a fusing number for the bonding wire. Perhaps it is the same as the max collector current.. 200mA.
What number is the right one, if any?
    \$\begingroup\$ I have seen it listed but I’m racking me brain to think on what. It was to do with a question on this site so maybe bc547, 2n3904 or maybe 2n2222..... \$\endgroup\$
    Commented Feb 1, 2018 at 19:32
    \$\begingroup\$ It would be related to secondary breakdown due to current crowding, but that's normally spec in the SOA plot for IC-VC. It would be less than IC max \$\endgroup\$
    – sstobbe
    Commented Feb 1, 2018 at 19:56
    \$\begingroup\$ Related: electronics.stackexchange.com/questions/158522/… \$\endgroup\$
    – vofa
    Commented Feb 1, 2018 at 19:57
    \$\begingroup\$ Found one on an ST BD139 datasheet: 0.5A. \$\endgroup\$
    – Oldfart
    Commented Feb 1, 2018 at 19:59
    \$\begingroup\$ Generally it is shown in power transistors' (BD139, BD243, 2N3055 etc) datasheets. But I cannot say the same thing for general purpose ones. \$\endgroup\$ Commented Feb 1, 2018 at 20:13
Aside from the answers here the NXP BC847 lists a maximum Ibm as 100mA for a <= 1ms pulse.
It is less than the maximum collector current under the same conditions.
  • \$\begingroup\$ Yup seen those, but no indication of continuous. I was toying with an idea to use the BE as a diode in a current detection circuit for a different question , but the current gets a tad large. \$\endgroup\$
    – Trevor_G
    Commented Feb 1, 2018 at 20:34
  • \$\begingroup\$ Maybe 50% if Ic is a good ball-park number in general though. \$\endgroup\$
    – Trevor_G
    Commented Feb 1, 2018 at 20:36
    \$\begingroup\$ @Trevor_G Depends on how brave you are. 10mA is mentioned in the testing of Vbe. \$\endgroup\$ Commented Feb 1, 2018 at 20:44
The assembly house will use the same size bond wire for all 3 leads. Unless the base metallization from bond-pad into the base region has narrow metal, I'd use the same # as emitter or collector. Some old datasheets would, with pride, show die photos.
