I bought a ftdi cable with the following pins.
  1. Vcc
  2. GND
  3. RX
  4. TX
  5. RTS
  6. CTS
It's possible to use this device to upload code to an ATmega328p using the avrdude utility?
When I run this line on linux terminal:
sudo avrdude -c ft232r -p ATMEGA328P -P "/dev/ttyUSB0" -b 57600 -U flash:w:led.hex
I get this output:
avrdude: invalid portname '/dev/ttyUSB0': use 'ft[0-9]+'
I know that some ft232r boards can be used for this purpose, but all of them that I've seen until now rely on the DTR pin, which I don't have access.
  • \$\begingroup\$ Are you trying to do ISP, or to talk to a bootloader? Your current command is an unworkable mix of the two, and you will need to make it definitively one or the other. \$\endgroup\$ Commented Feb 4, 2018 at 0:01
  • \$\begingroup\$ I'm trying to do a ISP, could please explain better how I'm making a mix of the two? \$\endgroup\$
    – Oshio
    Commented Feb 4, 2018 at 5:06
  • \$\begingroup\$ You're using a USB serial address only suitable for bootloader and other runtime communication, mixed up with an ISP command. \$\endgroup\$ Commented Feb 4, 2018 at 5:14
  • \$\begingroup\$ Yes I see that, @C_Elegans and Janka have already alerted me about that problem. I'm working on this, please see the C_Elegans answer and comments to understand what I've done so far. I appreciate your time. \$\endgroup\$
    – Oshio
    Commented Feb 4, 2018 at 5:23
According to this guide, you can modify your avrdude.conf to use a different pin for the reset signal than normal. So you would want to add the following to your avrdude.conf
programmer
  id    = "ft232r_mod";
  desc  = "FT232R Synchronous BitBang";
  type  = "ftdi_syncbb";
  connection_type = usb;
  miso  = 1;  # RxD
  sck   = 0;  # RTS
  mosi  = 2;  # TxD
  reset = 3;  # CTS
and invoke avrdude as avrdude -c ft232r_mod -p m328p -P ft0 -U flash:w:led.hex (making sure to use ft0 instead of the serial port name). Alternatively, if you post what your FTDI board is, there may be an exposed pad for the DTR signal, like on Adafruit's FTDI Friend. Finally if neither of those work, and you have a working arduino, you can use it as an isp.
  • \$\begingroup\$ Hello @C_Elegans I did what you suggest: sudo avrdude -c ft232r_mod -p ATMEGA328P -P ft0 -b 57600 -U flash:w:led.hex But when I hit enter, nothing happens. It's like the avrdude has entered in an infinite loop. I suspected it could be a connection issue and try to swap the MOSI and MISO wires but avrdude didn't change this odd behavior. \$\endgroup\$
    – Oshio
    Commented Feb 3, 2018 at 22:04
  • \$\begingroup\$ I also have already uploaded a blinky code in the chip and expected the device to be reseted before the burning process started, but it continues to run like nothing its happening. I manually grounded 328p's resest pin, but didn't work either. \$\endgroup\$
    – Oshio
    Commented Feb 3, 2018 at 22:09
  • \$\begingroup\$ Hmm. What happens if you remove the -U flash:w:led.hex? \$\endgroup\$
    – C_Elegans
    Commented Feb 3, 2018 at 23:09
  • \$\begingroup\$ Still the same. \$\endgroup\$
    – Oshio
    Commented Feb 4, 2018 at 1:19
  • \$\begingroup\$ So what is the current output of avrdude? \$\endgroup\$ Commented Feb 4, 2018 at 5:25
Avrdude needs to employ libftdi to get better control on the individual port lines of the adapter. Instead of /dev/ttyUSB0, it wants to read ft0 for the first FTDI interface.
