From this picture,when\$ V_{in} = V_{DD}\$,I know \$M_1\$ and \$M_3\$ will turn on,and \$M_2\$ will turn off because their \$ V_{gs} \$ are \$V_{DD}\$ and 0 ,but why will \$M_4\$ turn off,and \$V_B=V_{DD}\$, \$V_{out}=0\$ ?
If i know \$V_{out}=0\$ and \$V_B=V_{DD}\$ first,then of course i know \$M_4\$ will turn off ,but if now i don't know the value of \$V_B\$ and \$V_{out}\$,and neither do \$M_4\$ ,how do i know \$M_4\$ turn off,and \$V_B=V_{DD}\$, \$V_{out}=0\$ ?
  • 5
    \$\begingroup\$ How about recognizing good answers on previously raised questions or do you think you deserve free advice? \$\endgroup\$
    Feb 2, 2018 at 14:56
    \$\begingroup\$ i had did it,but some question is not the right answer \$\endgroup\$
    – Shine Sun
    Feb 2, 2018 at 14:58
    \$\begingroup\$ but some question is not the right answer Hmm, does that mean you already know what the right answer is? \$\endgroup\$ Feb 2, 2018 at 15:05
  • \$\begingroup\$ why M4 and M3 gates are floating ?? \$\endgroup\$ Feb 2, 2018 at 15:19
  • \$\begingroup\$ @TonyStewart.EEsince'75 That's what I thought as well but it is just drawn in a bad way. That node is actually \$V_{IN}\$. A simple vertical line to the \$V_{IN}\$ text would have fixed that, like is done at the left side of the circuit. \$\endgroup\$ Feb 2, 2018 at 15:22
As the gate of M4 (which is a PMOS) is \$V_{DD}\$, the only way to make M4 turn on is the take the bulk or drain or source connection of M4 at least \$V_t\$ above \$V_{DD}\$. So we would need \$V_{DD} + V_t\$ to be present somewhere in the circuit.
This can only happen if capacitor \$C_B\$ is first charged (with \$V_A\$ = GND and \$V_B\$ = \$V_{DD}\$) and then discharged by making \$V_A = V_{DD}\$ then there would for a short time be \$2*V_{DD}\$ present at \$V_B\$. But as \$C_B\$ discharges through M5, which is on, see Andy's answer, so the \$V_{GS}\$ of M4 must be zero, hence it is off.
If M3 turns on then M5 has to activate and this has to turn M4 off. If M3 is on and M4 off then Vout is zero.
  • \$\begingroup\$ why does M5 need to activate when M3 turn on? \$\endgroup\$
    – Shine Sun
    Feb 2, 2018 at 15:10
    \$\begingroup\$ M5 activates because M3 is shorting M5's gate to zero volts and M5's source is high. \$\endgroup\$
    Feb 2, 2018 at 15:20
