I'm want to use ADIsimPll to calculate the loop filter properties for a PLL I want to build. I read some things in the programs help topics which I find somehow strange. Maybe you guys can help me out with those.
- They define the loop bandwith as the frequency of unity gain for the open loop gain. Wouldn't it make more sense to use the closed loop gain instead?
- The open loop gain is defined as \$G(s) = \frac{K_d K_v F(s)}{N s}\$, where F(s) denotes the loop filter transfer function. Why is N in there? Normally, the open-loop-gain is defined as VCO-output/phase-error (or \$\frac{\Theta_O}{\Theta_{REF}}\$ in the diagram below) which is just \$\frac{K_d K_v F(s)}{s}\$. If this N is in there or not changes the loop bandwith drastically. Also the closed loop gain is influenced by this.
Here is a block diagram of the (type of) PLL I'm talking about.
