I need your advice regarding the USB 2.0 signals routing. When I reach the USB connectors, the data lines (D+ and D-) have to be swapped. I have two options there: 1) swap the lines using vias and go from top to bottom layer for a short, 2) make a loop around the connector, like in the following picture.
What is your suggestion, what is better option in therms of signal integrity ? I just wonder if this loop emphasizes antenna effect, but maybe the option with vias is worse.
P.S. Just to avoid confusion,bellow the top layer, there is a solid GND plane, so this split plane is power plane (layer 3), not the GND plane.
Thank you for your time, Igor
