I am familiar to the syntax described in here
net_type [msb:lsb] list_of_net_identifiers;
reg [msb:lsb] list_of_register_identifiers;
For example, to declare the 32bits memory address, I could use the syntax like
reg [31:0] address;
Also to declare the memory comprised of the 16 elements which consist of 32 bits each,
reg [31:0] mem [15:0];
However, I could frequently face the syntax like below to declare multidimensional arrays.
reg [31:0] mem [0:15]
I've googled it and found one related article in here. It seems that whether the larger number comes first or not, the first number before the colon (:) is the MSB and the LSB follows. It seems like the difference comes from the preference of coding.
However, I think mixing [31:0] and [0:15] style is little bit count-intuitive and confusing even though it depends on the preference. I could see a lot of mixing especially in the declaration of multi-dimensional arrays. Why is it allowed to be used? Is there any advantage that I couldn't notice?
