I am designing battery charging system. Datasheet of IC's says "Connection of switching ground to system ground, or any internal ground plane should be single-point." on PCB layout considerations. For this reason I decided to use "Net Tie" between GND and PGND.
I created net tie schematic rectangle(pin1 and pin2) and net tie footprint . You can see below.
When I am using Net Tie on my PCB I have seen Design Rule Problems.
Clearance Constraint(Collision <0.15mm) Between Pad on TopLayer and Track on Toplayer.
Short circuit Constraint Between Pad on Toplayer and Track on Toplayer.
Picture 1:
Picture 2:
https://s32.postimg.org/u3ttijdut/footprint.png
Note: Track width is 0.255mm (okey for design rule)
Picture 3:
How can I solve the problems? Do you have any advice for this problem?
By the way I checked this pdf: -Net Ties and How to Use Them- https://www.smtnet.com/library/files/upload/NetTies-and-How-to-Use-Them.pdf
