When I say more power, I know that fundamentally it takes more energy to move the speaker cone to produce lower frequency audio. However, in my experiences, higher frequency content takes up something like x10 less current than its lower frequency counterparts, and this is using similar impedance tweeter and woofers from the same amplifier output.
I know that the impedance value of the woofer doesn’t drop off that rapidly, so what’s with the way higher power consumption?
Does a higher frequency audio signal have a smaller amplitude or something of that nature? I’ve been trying to figure it out for some time but can’t seem to wrap my head around it.
Edit 1: To clarify this, impedance of subwoofers or woofers don’t change dramatically for frequencies before or after the resonant spike. So if you’re driving let’s say, a 10W speaker and 2W tweeter with the same amp ie the same voltage, how does the tweeter not get burnt out? Is there just more spectral content below a certain frequency in the overwhelming majority of songs?
    \$\begingroup\$ Are you perhaps thinking of perceptual loudness, where to hear the same level of a low frequency requires a much higher amplitude than a high frequency? \$\endgroup\$
    – loudnoises
    Commented Feb 4, 2018 at 10:52
  • \$\begingroup\$ No, I’m more of referring to the fact that higher frequency speakers are always used with lower power ratings, see edit 1. \$\endgroup\$
    – Michael E
    Commented Feb 4, 2018 at 21:36
The reason is that loudspeaker efficiency (how much sound pressure you get per Watt electrical input power) is much lower below the resonance frequency of a loudspeaker box.
Here's an example curve taken from this article:
The Y-axis is SPL and is a dB (power) scale so 10 dB difference means a factor 10 less power.
How steep the curve drops below that resonance frequency depends on the type of loudspeaker box, open or closed, if there's a bass reflex port or not.
So simply more power is needed to achieve the same sound pressure level at low frequencies compared to high frequencies.
What also plays a role is that out ears do not have a flat response. Our ears are most sensitive around 3 kHz. Our ears are quite insensitive to low frequencies so more sound pressure is needed anyway. Music's frequency content reflects that, the low frequency signals are much stronger than the high frequency ones.
Edit in response to Edit1:
Well, the tweeter would get damaged if you fed the speaker 10 kHz at 10 W. Most tweeters cannot handle that, they can only handle a few Watt. And that's all that is needed, a couple of Watts at 3 kHz is all that is needed to make you cover your ears. At low frequencies it is much different, a couple of Watt at a low frequency isn't that loud. There are two reasons for that: 1) your ears are less sensitive at low frequencies 2) speaker efficiency is a lot less at low frequencies.
In music the tweeter does receive a lot less power than a woofer. I would say that 95% or more of the power an audio amplifier has to deliver is in the low frequencies, so up to 200 Hz or so.
  • \$\begingroup\$ Thanks for this info! I was aware of this, I’m more of asking about power rating differences between different speakers, see edit 1 for clarification. \$\endgroup\$
    – Michael E
    Commented Feb 4, 2018 at 21:37
  • \$\begingroup\$ @MichaelE I added a section in response to your edit. \$\endgroup\$ Commented Feb 4, 2018 at 21:59
  • \$\begingroup\$ I see, so this is handled on the side of actually making the music? This is not something physical but more of something that is compensated for because of the aforementioned effects earlier in your post? \$\endgroup\$
    – Michael E
    Commented Feb 4, 2018 at 22:04
  • \$\begingroup\$ It is, mainly due to the frequency response of our ears. Also if the "power density" of music was flat, you'd have to set the volume based on the mid and higher frequencies as your ear is most sensitive to these. Setting the volume higher hurts your ears. Then you would not even hear the low frequencies as they would be too weak at the same power. \$\endgroup\$ Commented Feb 5, 2018 at 8:37
