I'm building a mobile robotics project for a class and I'm trying to figure out how to (or even if its necessary) to design a nice battery power system for it. I sort of wanted to learn how to build a nice power system so that I have the knowledge and to experiment a bit, but i'm sort of losing my mind on a part of the project which isn't super necessary. I basically wanted to try to build a few nice features.
1) USB power muxing, power the device off of USB power if its available
2) Battery Charging (Off of USB or some other connection)
3) Regulate 3.7V to 5V and 3.3V
4) Battery Protection, Undervolt, overvolt, short circuit are the main ones
5) Be able to provide enough power at 5V for (At least) 2 small steppers, 1 small DC motor, and 2 small servos. One of the steppers might be close to providing stall torque.
Basically, i've knocked up a few circuits that might work using several purpose built battery management IC's, but these small multi-purpose ic's are only really able to provide 1.5 - 2 A, which I really don't think is enough. Below is my latest idea.
This circuit uses
1) TP4056 for LiOn Charging
2) TPS2115 for automatic power muxing (max current is like 1.5 A)
3) TVL70033 for 3.3V linear regulator
4) TPS63002 for 5V switch mode boost
My friend is placing bets on which part of this circuit is going to catch fire. I'm getting pretty close to just trying to buy some ebay BMS chinese special and an ebay 5V boost converter and forgetting this whole thing because it's been a pain in the keister to get to this point. I've seen some power muxing solutions on here like this one but they're a bit complicated. I could also use a 5V boost manager and sort of build my own boost converter instead of buying an all in one IC to get some more current but i've never done that before and it looks difficult. How are medium power battery systems like this usually designed? Is this all more trouble than it's worth? Thanks for reading, I hope this question is slightly interesting.
Also as a completely unrelated question, how do you put out a lithium battery fire?
  • \$\begingroup\$ Consider your overall max power including surge starts and then your safe current limit on the battery 1C or C/5 etc. depending on battery quality/cost , operating time.. and then choose a more suitable battery size. It may end up being 2S2P rather than 1 cell. Do the math. Avoid Fires at all costs. batteryuniversity.com/learn/article/safety_concerns_with_li_ion \$\endgroup\$ – Sunnyskyguy EE75 Feb 4 '18 at 19:53
  • \$\begingroup\$ Thanks, I was trying to avoid multiple batteries because it complicates the charging circuitry (for good and safe performance you need balancing). It's probably unavoidable though. \$\endgroup\$ – jeb Feb 4 '18 at 20:54
  • \$\begingroup\$ @jeb Plan on some high-current inductors in VDD wires, to assist in localizing the ugly transient spikes of motors and switch-regs. Use the inductors, and 100uF electrolytics, to form low-pass filters. You'll need to sketch out the RTN paths, and avoid sharing high-current paths with sensitive circuits. \$\endgroup\$ – analogsystemsrf Feb 5 '18 at 6:23
  • \$\begingroup\$ @analogsystemsrf should the low pass filters be placed close to the motor drivers? There's really only motors on the and a few simple sensors on the +5V rail. I have a few microcontrollers on a 3.3V rail \$\endgroup\$ – jeb Feb 5 '18 at 22:08
