I'm using STM32Cube to generate the configuration. It creates the following code by default for MX_GPIO_Init in main.c:
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
However, I also want it to be triggered on falling, so I have to manually change it to:
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING_FALLING;
Since I need regularly to change the setup (because I am both a starter, and want to gradually add pins), is there a way in STM32CubeMX to set this, so it is generated?
  • \$\begingroup\$ You need to disable interrupts before changing the trigger edge. maybe run it as an ISR? \$\endgroup\$ – Sparky256 Feb 5 '18 at 0:09
  • \$\begingroup\$ @Sparky256 it's not about the code execution/order, it's about the generation of code from STM32CubeMX. I would expect a field/widget somewhere inside STM32CubeMX to set the trigger edge type (falling/rising/falling+rising). \$\endgroup\$ – Michel Keijzers Feb 5 '18 at 9:40
In STM32CubeMX under: Configuration -> GPIO -> GPIO -> GPIO Mode
