Take \$V_{d (on)}\$ to be 0.6V for simplicity.
What's \$V_o\$? Is it voltage across 1K Resistor?
So... what's the direction of current flow in the 1k resistor? Is it away from BAT3 towards \$V_o\$?
How do two diodes and two batteries (BAT1 and BAT2) being in parallel would affect \$V_o? \$
I think \$V_o\$ is voltage across R1 which is \$10V - i \cdot 1K - V_d - 9V = 0\$
\$ i_{R1} \cdot 1K = V_{R1} = 10V - V_d - 9V = 10 - 0.6 - 9 = 0.3V \$
KVL loop.
But if BAT3 was 5V, then what would be \$ V_o \$?
I know that in this case, current has to go from diodes towards BAT3, right?
Do I just look at one "branch" to calculate \$ V_o \$? For instance, the branch with upper diode, D1.
KVL loop 1:
So Vo = 9V + 0.6V - 5V ??
