7
Is there any difference between MOSFETs with a diode in their symbol and the HEXFET?
Also, is there a difference between MOSFETs with a diode in their symbol and other MOSFETs?
  • \$\begingroup\$ Welcome to EE stack exchange you might want to go to help and take the tour. Delete the bit about asking for a particular MOSFET, 'shopping' questions are not allowed here. Look at a few datasheets for the diode information. \$\endgroup\$
    – RoyC
    Commented Feb 5, 2018 at 8:43
  • \$\begingroup\$ @RoyC I stepped in and removed that part. Thanks for prompting the OP. \$\endgroup\$ Commented Feb 5, 2018 at 9:04
  • \$\begingroup\$ By HEXFET are you referring to the International Rectifier line of power FETs? \$\endgroup\$
    – Nick T
    Commented Feb 5, 2018 at 16:59
    \$\begingroup\$ related: Where does the MOSFET body diode come from?, Do MOSFETs have a diode built into them? \$\endgroup\$ Commented Feb 5, 2018 at 22:09
13
MOSFETs with a diode in their symbol are power MOSFETs, i.e. a class of MOSFETs whose structure has the channel between source and drain oriented "vertically" in the planar structure of the chip.
They are sometimes also called vertical MOSFETs for this reason, and they are designated also by the acronyms DMOS, VMOS or VDMOS (these acronyms refer to the shape of the structure viewed in the cross-section of the chip or to the fact that the structure is vertical).
This allows greater power dissipation and handling of higher power, compared to "older" lateral MOSFETs, whose channel "lies flat" on the chip surface, like the following image shows:
The vertical structure implies that a parasitic diode is formed across source and drain, that's why that diode is almost always depicted in the symbol.
Power MOSFETs comprise a large array of specific technologies, developed by individual manufacturer, which go under a plethora of trademark names, such as: HEXFET, TRENCHMOS, etc.. They are all power MOSFETs and they share the same symbol.
HEXFET is just the trade mark name of a power MOSFET by International Rectifier, so there is no difference between a power MOSFET and an HEXFET in the sense that an HEXFET is just a power MOSFET produced using a specific proprietary technology.
Note that, in reality, a power MOSFET (intended as a discrete device in a package) is made up of several individual MOSFETs (called cells) connected in parallel inside the chip. This is done to optimize efficiency and power handling capability of the device.
Keep in mind that "power MOSFET" doesn't necessarily mean "high power". The term was coined when the only MOSFETs available where tiny devices that could handle only milliwatts of power, therefore when the new technology became available they were dubbed "power MOSFETs" because they could handle much more power.
Taking as an example jellybean devices common nowadays, the 2N7000 is still a power MOSFET even if it can handle only 350mW max, whereas the IRFZ44N can handle 94W!
Nowadays "older" lateral MOSFETs are very specialized devices, rarely used as discrete components. Instead, they are used heavily in digital logic: the ubiquitous CMOS technology, which probably covers 99% of modern digital technology, makes use of complementary MOSFET (P-channel and N-channel) transistors as basic building blocks.
Note that I keep saying "older" lateral MOSFET, this is to avoid confusion with a more modern technology used to make power MOSFET, which employs a lateral (i.e. non-vertical) structure. These are devices optimized for power linear applications (i.e. where the transistor works as an amplifier and not as a switch), whereas the classic vertical power MOSFET is more suited for switching applications.
EDIT (to answer a doubt expressed in comments and clarify some points)
The choice of the symbol of the diode, rectifier vs. Zener, is somewhat arbitrary. The Zener symbol is chosen, most probably, to highlight the fact that, even when the MOSFET is OFF, there is a limitation on max Vds because of that diode entering breakdown. Many devices are characterized in that sense. See for example the 2N7000 datasheet I linked above (yellow emphasis mine):
As with any diode, bringing the device into breakdown put you at risk of damaging it. Entering breakdown is not in itself harmful, but in that region the current increases very quickly and the dissipated power consequently, too.
Actual Zener diodes are well characterized and their breakdown voltage is specified with a well defined range, therefore you can always control and limit the current so that the power doesn't exceed the max ratings of the device.
In a MOSFET, or other non-Zener diodes, the BD voltage is usually given as a minimum value, i.e. they give you that value so as to guarantee a maximum safe value for Vds. They don't specify a max BD-voltage value. This means that, taking that 2N7000G as an example, you may enter breakdown at (say) 60V , 70V or even at 80V.
Therefore you have no means, reading the datasheet, to guarantee that the power dissipation is under control: if you apply 65V, for example, you could have barely entered BD, so that the VI product is smallish and can be handled by the device, or you can be in full BD, where the current is huge and the VI product exceed the device ratings.
    \$\begingroup\$ That titbit about MOSFETs in parallel within a package reminds me of an amazing trip I had round the Infienon (née Eupec) IGBT factory in Warstein. Was incredible to see how this very high power devices were put together with multiple dice in parallel inside the large package, connected together with these seemingly tiny bonding wires! \$\endgroup\$
    – DiBosco
  • \$\begingroup\$ @DiBosco Yep! And the paralleling of the cells is an information that is quite difficult to find in documentation. Most papers and book talk about mosfets as individual devices and neglects the fact that discrete power mosfets are, in essence, sort of an IC with many such elementary devices in parallel! I myself didn't know that until fairly recently (~10 years ago)! \$\endgroup\$ Commented Feb 5, 2018 at 9:08
  • \$\begingroup\$ The older style of device is also used in analog multiplexers (transmission gates) because of the need to prevent the body diode from conducting by reverse biasing it :) \$\endgroup\$ Commented Feb 5, 2018 at 15:58
  • \$\begingroup\$ I've noted that the diode is usually shown as a Zener diode. Is this just to show that it has a particular reverse-bias breakdown voltage? Will reverse breakdown damage the device? \$\endgroup\$ Commented Feb 5, 2018 at 16:06
  • \$\begingroup\$ Thanks this helped. I would also like to know what it means when the MOSFET symbol has a zener diode instead? @LorenzoDonati \$\endgroup\$ Commented Feb 6, 2018 at 5:11
21
Actually all MOSFETs have two (parasitic) diodes.
This shows how a MOSFET on a chip can be constructed:
Note that both the Drain and the Source have a PN-junction to the Substrate (the purple region). These PN junctions form a diode, so between Drain and Substrate there's a diode and between Source and Substrate there's a diode.
HEXFETs and other Vertically oriented MOSFET devices might have a different buildup but the PN junctions, the Drain-Bulk and Source-Bulk diodes will always be present.
Most discrete MOSFETs do bot have a separate Substrate connection, instead the Source and Substrate are shorted. To use the MOSFET properly this needs to be done anyway so it is done in the package.
That leaves the Drain-Substrate diode and since the Source and Substrate are shorted, this diode sits between the Drain and Source contacts.
As you have noticed, some MOSFET symbols include this Drain-Source diode in the symbol just for clarity, others don't. But no matter what the symbol shows, that diode will always be present as it is an intrinsic structure of any MOS transistor.
  • \$\begingroup\$ +1 great answer. Personally I hate when folks use the symbol without the diode. The diode makes it so much easier to see if it is the right way around. \$\endgroup\$
    – Trevor_G
    Commented Feb 5, 2018 at 13:01
    \$\begingroup\$ I'm in integrated electronics, and you will find that nearly no one uses the symbol with the diode (i have yet to see one example). Furthermore, there is always the symbol with the arrow on the source side, which shows if the mosfet is connected the right way around. Lastly, it is perhaps interesting to note that silicon-on-insulator technologies (SOI) are increasingly used for there superior analog performance, at least on-chip. These devices don't have a parasitic diode connected to source and drain. \$\endgroup\$
    – pschulz
    Commented Feb 5, 2018 at 17:38
