Instead of using a $25 Li-Poly battery with a $10 charger, I was going to use one of these- https://hackaday.io/project/46436-3-cell-rc-battery-pack-made-with-18650-batteries What I was wondering Is how it would compare? It seems safer than a Li-Po, and cheaper, seeing how I have a bunch of those batteries sitting around, but performance wise, I'm clueless.
  • \$\begingroup\$ The Tesla model S uses them so I don't see why you shouldn't. \$\endgroup\$ – Finbarr Feb 5 '18 at 18:20
  • \$\begingroup\$ Because they're not the right kind of batteries. \$\endgroup\$ – Bryan Boettcher Feb 5 '18 at 19:27
There's a few things wrong here:
1) A $10 charger is a bad idea, unless it's a trickle charger through the balance leads.
2) A $25 prismatic high-C lipo is a very different beast than 18650s, barring very specific ones (the LG HG2, Sony VTC5, etc) and very specific flight modes (minimum time-in-the-air of 30 minutes or longer). Most 18650s are sub-1C discharge ratings.
3) You need to spot-weld the tabs to the batteries. Do not solder them.
You also didn't say what kind of 18650s you already have.
  • \$\begingroup\$ sorry, i have these ultra fire ones... shopnis.ru/akkumulator-18650 and I was going to rig them without welding, maybe make a really small holder for them, them I can pop them out and put them in my power bank and charge them from there \$\endgroup\$ – J. Doe Feb 6 '18 at 1:11
  • \$\begingroup\$ i mean, in a 3s2p configuration, it would be fine, right? check this out- rcgroups.com/forums/… \$\endgroup\$ – J. Doe Feb 6 '18 at 1:30
  • \$\begingroup\$ I can't stop you from doing it. It's going to end in fire. Those cells will live up to their name in this usage. \$\endgroup\$ – Bryan Boettcher Feb 6 '18 at 15:25
