I have an issue with a delay routine that I am writing for use on a PIC32, the PIC32MX664F128H in particular.
I have two separate delay functions, which use the same lower-level delay routine: one for a millisecond delay and another for a microsecond delay. Below follows the code for each function:
void TIMER_DelayMillisec(unsigned int duration)
    unsigned int timerCount;
    /* Timer counter for 1 millisecond delay */
    timerCount = (MILLISECOND * systemClock);
    /* Run the timer routine */
    timerRoutine(duration, timerCount);
} /* TIMER_DelayMillisec() */
and...
void TIMER_DelayMicrosec(unsigned int duration)
    /* Timer counter for 1 microsecond delay */
    timerCount = (MICROSECOND * systemClock);
} /* TIMER_DelayMicrosec() */
In the above two functions, the values for the defines are MILLISECOND = 0.001 and MICROSECOND = 0.000001. The variable "systemClock" gets initialized on startup. In this particular case, this value is 80 000 000 (for 80 MHz). Below follows the code for the lower-level delay routine:
static void timerRoutine(unsigned int duration,
                         unsigned int timerCount)
    unsigned int divCount = 2u;
    /* If the timer counter is less than 1, round it up to the nearest integer,
     * i.e. 1 */
    if (timerCount < 1)
        timerCount = 1;
    } /* if */
    /* If the timerCount value is larger than 0xFFFF,
     * divide the value by 2 until it is within this range. */
    if (timerCount > 0xFFFF)
        timerCount = timerCount / divCount;
        duration = duration * divCount;
    /* Set the PR register to the max value */
    PR1 = 0xFFFF;
    /* Enable the timer */
    T1CONbits.ON = 1;
    TMR1 = 0u;
    /* Loop the amount of times required for the delay */
    while(duration > 0)
        /* Wait until timer reaches the required value */
        while(TMR1 < timerCount);
        duration--;
        /* Reset timer */
        TMR1 = 0u;
    } /* while */
    /* Disable the timer */
    T1CONbits.ON = 0;
} /* timerRoutine() */
Some explanation on the above routine: The delay routine uses the PIC32's Timer1 (which is a 16-bit timer). The TMR1 register gets incremented with each tick of the peripheral bus clock (PBCLK), which is set to 80 MHz. Therefore, the period of one clock tick is: $$T_{PBCLK} = 1/f_{PBCLK} = 1/80 MHz$$ For example, for a 1 millisecond delay, the equivalent amount of clock ticks would then be: $$ timerCount = (1 sec/1000 millisec) / T_{PBCLK} $$ thus, $$ timerCount = 0.001 / T_{PBCLK} = 0.001 * f_{PBCLK}$$ $$ timerCount = MILLISECOND * f_{PBCLK}$$
Therefore, timerCount is the amount of clock ticks for the "unit" time delay (of either a millisecond or microsecond). The timerRoutine() function then uses this value of timerCount to perform the delay by comparing the TMR1 register against this value. When the TMR1 register value reaches the value of timerCount, the correct amount of time for the "unit" delay has passed, and the TMR1 register is re-initialized. The total duration, denoted by the variable duration is obtained by repeating this loop for duration amount of times. The part where the values of timerCount and duration are manipulated (by division and multiplication, respectively), is there for when the value of timerCount exceeds the maximum 16-bit value (of 0xFFFF) for long delays. The values of these two variables are adjusted accordingly.
These routines are tested by toggling one of the PIC32's I/O pins at a specified rate, which is obtained by calling the particular delay function in-between the changing of the I/O pin states, and then measuring the actual time difference between the I/O pin states:
unsigned int delay = 1u;
while (TRUE)
    IOPin = HIGH;
    TIMER_DelayMillisec(delay);
    IOPin = LOW;
The same concept is used to test the microsecond delay routine, by calling TIMER_DelayMicrosec() instead of TIMER_DelayMillisec() with the required delay value.
Herewith follows some test results. First, the millisecond delay routine is tested. For 1 millisecond: 1 millisecond
For 5 milliseconds: 5 milliseconds
It can be seen from the above two images that the delay routine for the millisecond delay function is essentially spot-on, with equal delay between the HIGH and LOW pulses.
However, something totally different happens for the microsecond delay function. For 1000 microseconds (which should equal 1 millisecond as above): 1000 microseconds
For 500 microseconds: 500 microseconds
For 250 microseconds: 250 microseconds
For 100 microseconds: 100 microseconds
As can be seen from the above images for the microsecond delay function, there is a difference between the delay time of the HIGH and LOW pulses, with the delay from the ON-to-OFF pulse being significantly higher than the delay from the OFF-to-ON pulse. Furthermore, this effect gets more prominent as the delay time decreases.
Considering that, for example, for a delay of 1 millisecond, the delay loop for the millisecond delay routine executes exactly the same amount of times as for the microsecond delay routine for a delay of 1000 microseconds. Therefore, the actual delay times should be equal.
The only thing that comes to mind that could cause this variance in actual delay times is the amount of overhead during the whole of the delay routine. Consequently, the expected "drifting" effect should have been worse for the millisecond delay routine than for the microsecond delay routine, since it involves more iterations of the delay loop for a longer delay. However, rather counter-intuitively, the observed results point to the exact opposite, which indicates that there is probably something else causing the "drifting" effect.
What could be happening here and how can this be fixed?
UPDATE:
Through further thorough investigation I have found the problem. Perhaps I should've mentioned it from the very start, but the particular I/O pin that I used for this testing is optically isolated (due to the nature of the application). Probing the PIC's I/O pin directly yielded perfect square waves for my delay test values. My measurements were all at the output of the optocoupler. The problem is undoubtedly due to the optocoupler's switching characteristics, and is thus not software related.
Nevertheless, thank you to those who have made suggestions in improving the delay routine. These suggestions will certainly be considered.
  • \$\begingroup\$ You lose LSB when performing timerCount = timerCount / divCount. Did you emulate/trace the code in IDE (if it is possible)? \$\endgroup\$
    – Anonymous
    Commented Feb 5, 2018 at 21:07
  • \$\begingroup\$ @Anonymous: That makes sense. However, when the timerCount is halved, the duration is doubled, so there shouldn't be any time lost as a result of the division. \$\endgroup\$
    – wave.jaco
    Commented Feb 5, 2018 at 21:36
  • \$\begingroup\$ @Samuel: "unsigned int" is 32 bits on the platform that I am using. However, Timer1 is a 16-bit timer, and thus its associated count registers (such as PR1, and TMR1) are 16 bit values. Therefore, 32-bit values are possible and valid, but the timer peripheral itself is only 16-bit. \$\endgroup\$
    – wave.jaco
    Commented Feb 5, 2018 at 21:39
  • \$\begingroup\$ Why not then just use lower 15 bits for timer, and use upper 17 bits (actually up to 15 bits) for counter? Why complicating things with another loop (and thus CPU time spent) on fitting 32-bit value into two 16-bit values if they can be simply and readily obtained bitwise? E.g. duration=timerCount>>15 and timerCount&=0x7FFF. \$\endgroup\$
    – Anonymous
    Commented Feb 5, 2018 at 21:53
  • \$\begingroup\$ PIC32 is a mips, a word/unsigned int is 32 bits. easy to confirm though various ways. \$\endgroup\$
    – old_timer
    Commented Feb 5, 2018 at 22:21
Through further thorough investigation I have found the problem. Perhaps I should've mentioned it from the very start, but the particular I/O pin that I used for this testing is optically isolated (due to the nature of the application). Probing the PIC's I/O pin directly yielded perfect square waves for my delay test values. My measurements were all at the output of the optocoupler, where the peculiar results were obtained from. The problem is undoubtedly due to the optocoupler's switching characteristics, and is thus not software related.
UPDATE (for the curious-minded):
Herewith follows the output of the PIC's I/O (green signal) vs. the optocoupler output (yellow signal):
Optocoupler vs PIC
It can be clearly seen that the optocoupler has a turn OFF-time of about 56 microseconds - almost right on par with what the datasheet says (typ. 40 microseconds)! This is one of the reasons why the timing overall looked inaccurate. Furthermore, the phenomenon of the "drifting" effect that worsens with shorter delays, is due to the fact that the optocoupler output still takes about 56 microseconds to turn off, regardless of the delay length. By the time that the optocoupler output reaches the OFF state, the next ON-pulse seems to occur earlier than it should, when in actual fact the optocoupler output turned off later than it should.
ALWAYS read the datasheet!
