First I apologize for such an ambiguous title. I am reading Code by Charles Petzold during my leisure time and have a question that I can't figure out by myself.
It is about Chapter 21, in which Code tries to build a RAM for 8080 processor out of memory chips 2012. To summarize, 8080 has 16-digit addresses, 8-digit data input and output respectively, while 2012 has 10-digit addresses, 1-digit data input and output respectively. Hence, eight of 2012 chips are wired together to store the entire 8-bit, and such 8-chip group is called a bank. Each memory board consists 4 of such banks.
Then, because we have 4 banks,
If you recall the messy details of combining RAM arrays in Chapter 16, you might assume that we also need eight 4-to-1 Selectors to select the correct data output signals from the four banks of memory. But we don't, and here's why
Here comes my first question:
  1. Why do we need EIGHT 4-to-1 selectores? 8 chips are wired together as a whole, and their signals are the same as other ones in the same bank. More precisely, I know 8 of them work, but I am wondering whether ONE is enough. (I understand we are not using 4-to-1 selector, just want to finish the thought experiment).
Then, it explains why:
Normally, the output signals of TTL-compatible integrated circuits are either greater than 2.2 volts (for a logical 1) or less than 0.4 volts (for a logical 0). But what happens if you try connecting outputs? If one integrated circuit has a 1 output and another has a 0 output, and these two outputs are connected, what will result? You can't really tell, and that's why outputs of integrated circuits aren't normally connected together.
I understand the part that circuits are not normally connected together. The question however is
  1. When had we connected them if we ever followed 4-to-1 selector design? Were we not using an OR logic gate? (Again, I know we are not using this design, just want to make sure what would've happened if we had done it.)
A rough diagram that I have in mind is as follows (I am not sure if it is clear enough, if not, could some one points me a online diagram website and I'll try to make it as clear as possible): enter image description here
  • \$\begingroup\$ Welcome to EE.SE. Please refine your questions to just the important ones. Idle speculation is something we do not have time for. Have you looked up 4 to 1 or 2 to 1 mux decoders? Please do some research of your own. \$\endgroup\$
    – user105652
    Feb 6, 2018 at 0:28
  • \$\begingroup\$ Thanks for your comment. However I have done my work. I do know what it is a 4-to-1 selector - if you look at the left top corner there is a selector (made up of 2 switches). If you could read my question more patiently, you should find out I am not having idle speculation (at least I drew the diagram. If it is too trivial for you, I would much appreciate it if you can explain them in one or two sentences.). \$\endgroup\$ Feb 6, 2018 at 0:42
  • \$\begingroup\$ @jsotola Code is trying to build a computer from scratch.Before this point, only 2-state selectors introduced. He tries to explain two outputs should not connect to each other, and a buffer is needed. <-I get all these parts and know in reality we do not multiplex the outputs. However, in this particular case, even if 2012 had only two states, I think we can avoid connect two of them by an OR gate. I.E. his reasoning doesn't persuade me as of why we not use multiplex for the outputs (the outputs do not connect directly). I'd like to know which parts of my thoughts are wrong \$\endgroup\$ Feb 6, 2018 at 2:01
  • \$\begingroup\$ @jsotola thank you for comments. I guess I didn't make myself clear. Let me try again. Code is trying to explain why we use tri-state design instead of 4-to-1 selector (Or why not multiplex outputs). Although we use 2012 as an example, at this point, we are assuming a 2012 without the tri-state (only after explaining undefined behavior of connecting two outputs, he introduced tri-state). However, I do not see the disadvantage of using normal 2-state chips because we can use OR gate instead of connecting output signals together. Please let me know if I am making the question a little clearer. \$\endgroup\$ Feb 6, 2018 at 4:54
  • \$\begingroup\$ i understand now, i think .... tri-state memory chips would use less external circuitry. ... the delay through the OR gate or through the multiplexer would add to the "access time" ... with the OR gate arrangement the memory chip output would have to be guaranteed to be LOW for all chips that are not being read \$\endgroup\$
    – jsotola
    Feb 6, 2018 at 5:08
I can't find a datasheet for a 2012 memory, but I would expect it to have one or more Enable or Read inputs, and tri-state outputs.
If the outputs are not enabled, they would be in a high impedance state - the memory chip would not be driving the outputs either high or low. This would permit the outputs of several chips to be connected in parallel. Only one chip at a time would have its outputs enabled, so there would be no need for a selector to choose which chip to read.
You would, however, need an address decoder (like a 74LS138) driven by the upper address lines to select which memory chip will have its outputs enabled.
  • \$\begingroup\$ Thank you Peter. I understand what tri-state is. I do appreciate the high-impedance state. The problem I can't figure out is if, supposedly, we use 4-1 selector, I cannot see a problem as described in Code, i.e. I don't see any two outputs are connected. If that helps clarify the problem. \$\endgroup\$ Feb 6, 2018 at 0:44
  • \$\begingroup\$ If the memory chips don't have tri-state outputs, you would need one 4->1 selector for each memory bit - for an 8-bit wide memory array, that would mean 8 selectors. \$\endgroup\$ Feb 6, 2018 at 0:57
  • \$\begingroup\$ Code is trying to build a computer from scratch. Here it is trying to introduce the tri-state. Before this point, only 2-state selectors introduced. He tries to explain is two outputs should not connect to each other (this part I understand), and a buffer is needed. <-I get all these parts. However, in this case, even 2012 only has two states, I think we can avoid connect two of them by an OR gate. I'd like to know if my thought(diagram) misses any part about the avoidance. \$\endgroup\$ Feb 6, 2018 at 1:02
  • \$\begingroup\$ Hey @peter, yes! that's my first question. Why do we need 8? these 8 chips are wired together. A selector seems good to me. In the diagram I drew, only two switches are needed. they just send the same signal to combine any 2012 output signal in the same bank. \$\endgroup\$ Feb 6, 2018 at 1:16
  • \$\begingroup\$ The 2012 memory is only 1 bit wide, apparently, so you need eight of them to store 8-bit bytes. Your diagram appears to merge the outputs of all the 2012s into a single data bit, rather than into an 8 bit byte. \$\endgroup\$ Feb 6, 2018 at 1:25
