Here is my code to compute the sine and cosine of the input angle using the CORDIC algorithm:
Design code :
`define K 32'h26dd3b6a  // = 0.6072529350088814
`define BETA_0  32'h3243f6a9  // = atan 2^0     = 0.7853981633974483
`define BETA_1  32'h1dac6705  // = atan 2^(-1)  = 0.4636476090008061
`define BETA_2  32'h0fadbafd  // = atan 2^(-2)  = 0.24497866312686414
`define BETA_3  32'h07f56ea7  // = atan 2^(-3)  = 0.12435499454676144
`define BETA_4  32'h03feab77  // = atan 2^(-4)  = 0.06241880999595735
`define BETA_5  32'h01ffd55c  // = atan 2^(-5)  = 0.031239833430268277
`define BETA_6  32'h00fffaab  // = atan 2^(-6)  = 0.015623728620476831
`define BETA_7  32'h007fff55  // = atan 2^(-7)  = 0.007812341060101111
`define BETA_8  32'h003fffeb  // = atan 2^(-8)  = 0.0039062301319669718
`define BETA_9  32'h001ffffd  // = atan 2^(-9)  = 0.0019531225164788188
`define BETA_10 32'h00100000  // = atan 2^(-10) = 0.0009765621895593195
`define BETA_11 32'h00080000  // = atan 2^(-11) = 0.0004882812111948983
`define BETA_12 32'h00040000  // = atan 2^(-12) = 0.00024414062014936177
`define BETA_13 32'h00020000  // = atan 2^(-13) = 0.00012207031189367021
`define BETA_14 32'h00010000  // = atan 2^(-14) = 6.103515617420877e-05
`define BETA_15 32'h00008000  // = atan 2^(-15) = 3.0517578115526096e-05
`define BETA_16 32'h00004000  // = atan 2^(-16) = 1.5258789061315762e-05
`define BETA_17 32'h00002000  // = atan 2^(-17) = 7.62939453110197e-06
`define BETA_18 32'h00001000  // = atan 2^(-18) = 3.814697265606496e-06
`define BETA_19 32'h00000800  // = atan 2^(-19) = 1.907348632810187e-06
`define BETA_20 32'h00000400  // = atan 2^(-20) = 9.536743164059608e-07
`define BETA_21 32'h00000200  // = atan 2^(-21) = 4.7683715820308884e-07
`define BETA_22 32'h00000100  // = atan 2^(-22) = 2.3841857910155797e-07
`define BETA_23 32'h00000080  // = atan 2^(-23) = 1.1920928955078068e-07
`define BETA_24 32'h00000040  // = atan 2^(-24) = 5.960464477539055e-08
`define BETA_25 32'h00000020  // = atan 2^(-25) = 2.9802322387695303e-08
`define BETA_26 32'h00000010  // = atan 2^(-26) = 1.4901161193847655e-08
`define BETA_27 32'h00000008  // = atan 2^(-27) = 7.450580596923828e-09
`define BETA_28 32'h00000004  // = atan 2^(-28) = 3.725290298461914e-09
`define BETA_29 32'h00000002  // = atan 2^(-29) = 1.862645149230957e-09
`define BETA_30 32'h00000001  // = atan 2^(-30) = 9.313225746154785e-10
`define BETA_31 32'h00000000  // = atan 2^(-31) = 4.656612873077393e-10
module cordic(
    angle,
    clock,    // Master clock
    reset,    // Master asynchronous reset (active-high)
    start,    // An input signal that the user of this module should set to high when computation should begin
    angle_in, // Input angle
    cos_out,  // Output value for cosine of angle
    sin_out   // Output value for sine of angle
input clock;
input reset;
input start;
input [31:0] angle_in;
output [31:0] cos_out;
output [31:0] sin_out;
wire [31:0] cos_out = cos;
wire [31:0] sin_out = sin;
reg [31:0] cos;
reg [31:0] sin;
reg [31:0] angle;
reg [4:0] count;
reg state;
reg [31:0] cos_next;
reg [31:0] sin_next;
reg [31:0] angle_next;
reg [4:0] count_next;
reg state_next;
always @(posedge clock or posedge reset) begin
    if (reset) begin
        cos <= 0;
        sin <= 0;
        angle <= 0;
        count <= 0;
        state <= 0;
    end else begin
        cos <= cos_next;
        sin <= sin_next;
        angle <= angle_next;
        count <= count_next;
        state <= state_next;
    end
end
always @* begin
    // Set all logic regs to a value to prevent any of them holding the value
    // from last tick and hence being misinterpreted as hardware registers.
    cos_next = cos;
    sin_next = sin;
    angle_next = angle;
    count_next = count;
    state_next = state;
    if (state) begin
        // Compute mode.
        cos_next = cos + (direction_negative ? sin_shr : -sin_shr);
        sin_next = sin + (direction_negative ? -cos_shr : cos_shr);
        angle_next = angle + (direction_negative ? beta : -beta);
        count_next = count + 1;
        if (count == 31) begin
            // If this is the last iteration, go back to the idle state.
            state_next = 0;
        end
    end
    else begin
        // Idle mode.
        if (start) begin
            cos_next = `K;         // Set up initial value for cos.
            sin_next = 0;          // Set up initial value for sin.
            angle_next = angle_in; // Latch input angle into the angle register.
            count_next = 0;        // Set up counter.
            state_next = 1;        // Go to compute mode.
        end
    end
end
wire [31:0] cos_signbits = {32{cos[31]}};
wire [31:0] sin_signbits = {32{sin[31]}};
wire [31:0] cos_shr = {cos_signbits, cos} >> count;
wire [31:0] sin_shr = {sin_signbits, sin} >> count;
wire direction_negative = angle[31];
wire [31:0] beta_lut [0:31];
assign beta_lut[0] = `BETA_0;
assign beta_lut[1] = `BETA_1;
assign beta_lut[2] = `BETA_2;
assign beta_lut[3] = `BETA_3;
assign beta_lut[4] = `BETA_4;
assign beta_lut[5] = `BETA_5;
assign beta_lut[6] = `BETA_6;
assign beta_lut[7] = `BETA_7;
assign beta_lut[8] = `BETA_8;
assign beta_lut[9] = `BETA_9;
assign beta_lut[10] = `BETA_10;
assign beta_lut[11] = `BETA_11;
assign beta_lut[12] = `BETA_12;
assign beta_lut[13] = `BETA_13;
assign beta_lut[14] = `BETA_14;
assign beta_lut[15] = `BETA_15;
assign beta_lut[16] = `BETA_16;
assign beta_lut[17] = `BETA_17;
assign beta_lut[18] = `BETA_18;
assign beta_lut[19] = `BETA_19;
assign beta_lut[20] = `BETA_20;
assign beta_lut[21] = `BETA_21;
assign beta_lut[22] = `BETA_22;
assign beta_lut[23] = `BETA_23;
assign beta_lut[24] = `BETA_24;
assign beta_lut[25] = `BETA_25;
assign beta_lut[26] = `BETA_26;
assign beta_lut[27] = `BETA_27;
assign beta_lut[28] = `BETA_28;
assign beta_lut[29] = `BETA_29;
assign beta_lut[30] = `BETA_30;
assign beta_lut[31] = `BETA_31;
wire [31:0] beta = beta_lut[count];
endmodule
Simulation Code/Test Bench:
module cordic_tb();
    reg clock = 0;
    reg reset = 0;
    reg start = 0;
    wire [31:0] cos_out;
    wire [31:0] sin_out;
    wire [31:0] angle;
    cordic sub_method(
        .angle(angle),
        .clock(clock),
        .reset(reset),
        .start(start),
        .angle_in(32'hc0000000),
        .cos_out(cos_out),
        .sin_out(sin_out)
    always #5 clock = ~clock;
    initial begin
        $display("c r s cos      sin");
        $display("- - - -------- --------");
        $monitor("%b %b %b %h %h %h", clock, reset, start, cos_out, sin_out, angle);
        #12 reset = 1;
        #15 reset = 0;
        #20 start = 1;
        #10 start = 0;
        #330 $finish;
    end
endmodule
The error when I simulate the Verilog code in Vivado 2014 is:
angle is not a port failed synthesis
Can anyone point out the cause of the error?
You forgot to assign a port direction to angle:
module cordic(
    angle,    // <<<<<<<<<<<<< !!!!!!
    start,    // An input signal ...
// Where is angle ??????
input clock;
input reset;
input start;
  • \$\begingroup\$ Thanks for replying. How shall I assign port direction to angle? It's clearly neither an input nor output. That's why I defined it as reg. reg [31:0] cos; reg [31:0] sin; reg [31:0] angle; // defined angle reg [4:0] count; reg state; \$\endgroup\$
    – Sank_BE
    Feb 7, 2018 at 9:01
  • \$\begingroup\$ You clear the angle during a reset just like cos, sin, count etc. That suggest to me it is an output. Why do you think it's is not? Maybe I am not following the algorithm correctly. \$\endgroup\$
    – Oldfart
    Feb 7, 2018 at 9:14
  • \$\begingroup\$ Yes! Thanks it works. I updated the code as output [31:0] angle; Reg part still remains as angle clearly is not the output like sin_out etc. Thanks again! \$\endgroup\$
    – Sank_BE
    Feb 7, 2018 at 9:26
  • \$\begingroup\$ Let me get this straight: you don't use angle externally? In that case just drop it from the port list. Just keep it internal like cos_next, sin_next etc. \$\endgroup\$
    – Oldfart
    Feb 7, 2018 at 9:31
  • \$\begingroup\$ So you're saying I remove it from the port and leave it reg as it is? Ok will try and get back.. \$\endgroup\$
    – Sank_BE
    Feb 7, 2018 at 10:10
