I'm trying to interface a 4-wire resistive touchscreen to a STM32F429 Discovery board but I can't figure out how it works. I want the MCU to detect a touch so I configured the 4 pins like this:
X+ --> input w/pullup connected to EXTI external interrupt
X- --> input floating (tristated)
Y+ --> input floating (tristated)
Y- --> output to GND
in this configuration I should be able to detect a touch and trigger an interrupt on the EXTI line so I can enter a ISR and sample the x and y values with the ADC. But when I connect the X- pin the X+ pin goes to near GND. It seems like current flows between X+ and X- (so the X- is not tristated?). Here's the code I use to configure the GPIO pins:
GPIO_InitTypeDef gpio;
gpio.Pin = GPIO_PIN_2 | GPIO_PIN_1;
gpio.Mode = GPIO_MODE_INPUT;
gpio.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &gpio);
gpio.Pin = GPIO_PIN_0;
gpio.Pull = GPIO_PULLUP;
gpio.Pin = GPIO_PIN_5;
gpio.Mode = GPIO_MODE_OUTPUT_PP;
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET);
/* initialization using registers, works the same as above */
// /* Xr and Yu open (input floating) */
// GPIOA->MODER &= ~(GPIO_MODER_MODE2 | GPIO_MODER_MODE1);
// GPIOA->PUPDR &= ~(GPIO_PUPDR_PUPD2 | GPIO_PUPDR_PUPD1);
// /* Xl input with pull-up */
// GPIOA->MODER &= ~GPIO_MODER_MODE0;
// GPIOA->PUPDR |= GPIO_PUPDR_PUPD0_0;
// /* Yd to GND (output set to 0) */
// GPIOA->MODER |= GPIO_MODER_MODE5_0;
// GPIOA->ODR &= ~GPIO_ODR_OD5;
I can't understand what I am doing wrong or how to configure the tristated pins correctly so they don't pull down the X+ pin.
