I'd like to model a brushless motor's (BLDC) dynamic response using Matlab. I'm controlling the motor by an Elesctonic Speed Controller (ESC). I'd like to derive a transfer function of such a circuit with shaft's angular speed being its output (as here) and with current being its input. I'm powering the whole plant using a constant 11.1V battery source.
BLDC electromechanical model
In the picture above, one could write equations for the electrical part of the model as:
\$ L \frac{di}{dt} + Ri = V - K \dot{\theta} \$ (1)
with K being the back-emf constant and the mechanical part can be modeled as (Newton's second law):
\$ J \ddot{\theta} + b \dot{\theta} = Ki \$. (2)
It's easy to connect those two equations and derive a transfer function \$ \frac{\dot{\theta}}{V} \$. I'm also expecting it must be possible to derive a transfer function of the form \$ \frac{\dot{\theta}}{i} \$. I imagine I could solve my problem by substituting \$ V \$ for \$ i \$ in equation (2) - I just don't know how.
  • \$\begingroup\$ Are you using constant current or constant voltage? In the title soy say CC and then in the body of the question CV. \$\endgroup\$
    – AndrejaKo
    Jul 11, 2012 at 10:10
  • \$\begingroup\$ The title says "current source". I'm using a 11.1V battery and control motor's speed by differentiating current. \$\endgroup\$
    – mmm
    Jul 11, 2012 at 10:29
    \$\begingroup\$ You can either model the angular velocity as a function of the applied voltage (CV) or as a function of applied current (CC). You can't have both at the same time since the voltage and current are interdependent. \$\endgroup\$
    – MikeJ-UK
    Jul 11, 2012 at 10:33
  • \$\begingroup\$ Yes, I expect it to be possible and the solution to be pretty easy. I'm just stuck on it and don't see how. I rephrased the question and added some details, to be more specific. \$\endgroup\$
    – mmm
    Jul 11, 2012 at 10:58
If you are driving the motor with a known voltage, the page you linked to gives you the answer so I assume you want to drive the motor with a controlled current.
Since the motor's torque is proportional to current, you can forget the resistance, inductance and back-emf constants.
\$T = K.i\$
and
\$T=J\ddot{\theta}+b\dot{\theta}\$
this can be expressed as
\$s(Js+b)\theta=Ki\$
(from your linked article), so
\$\theta = \dfrac{Ki}{s(Js+b)}\$
and
\$\dfrac{\dot{\theta}}{i} = \dfrac{K}{Js+b}\$
Of course any current source has a finite voltage compliance, so you will also need to compute the voltage as a function of current to ensure that the current source stays under control.
  • \$\begingroup\$ Thanks. I knew the answer must be ready and waiting on the referenced page, just couldn't link it :). \$\endgroup\$
    – mmm
    Jul 11, 2012 at 12:41
  • \$\begingroup\$ somebody please fix this [math processing error]. \$\endgroup\$ Nov 1, 2012 at 19:29
