I am solving objective questions from my book but the main problem is that it doesn't have solutions and in following question I don't know what type of question is this. First I am thinking its Wheatstone bridge related but its not. And resistance are in series but its not. So please tell me what type of question is this and how to solve it.
Here's one I draw before but above one is confusing.
  • \$\begingroup\$ Did you try redrawing it? \$\endgroup\$ Feb 9, 2018 at 17:11
  • \$\begingroup\$ Yes I try but totally puzzled. I can draw where connection also has resistance but here not. \$\endgroup\$ Feb 9, 2018 at 17:14
  • \$\begingroup\$ Do you feel like sharing any of your tries so that we can tell you where you went wrong? \$\endgroup\$ Feb 9, 2018 at 17:14
  • \$\begingroup\$ First of all I give names to all points from A to F. Then I try to redraw like any other question but I am unable. \$\endgroup\$ Feb 9, 2018 at 17:18
    \$\begingroup\$ Here's a clue - count the independent nodes in the circuit and what do you get. Then ask yourself how many ways you can arrange 3 resistors with these nodes. \$\endgroup\$
    Feb 9, 2018 at 17:25
Now why was that a problem? ( lack of numbering Nodes? )
  • \$\begingroup\$ @MichelKeijzers look more closely at your original circuit. Every resistor has V1+ at one end and V1- at the other. They are all in parallel, just drawn in a way to confuse you. \$\endgroup\$
    – Trevor_G
    Feb 9, 2018 at 17:49
  • \$\begingroup\$ @Trevor_G Sorry I removed my comment because I saw that they are indeed equal :-) \$\endgroup\$ Feb 9, 2018 at 17:50
  • \$\begingroup\$ How you changed them into parallel? \$\endgroup\$ Feb 9, 2018 at 17:54
  • \$\begingroup\$ I identified Node 1 and 2 at each end of each resistor and redrew. You can do this with more complex ccts by drawing nodes in more logical positions then connecting between same nodes. This cct has only 2 nodes but 5 dots, so 3 are redundant. remember this. Nodes must be unique. \$\endgroup\$ Feb 9, 2018 at 17:59
Re-drawing these circuits helps a great deal to find a simple solution - Andy makes a good suggestion to reduce the apparent number of nodes.
At first glance, it appears that there are four nodes...
Andy suggests that Node 1 is not independent from Node 3 - they are the same. And similarly, Node 2 is the same as Node 4.
So there are really only two nodes in this circuit. One of them connects to the "+" end of the battery, the other connects to the "-" end of the battery.
No one would publish a circuit diagram like that shown above. It is a book exercise to help you reduce circuits to their simplest form. Becoming adept at this skill is an important one for anyone dealing with circuits.
  • \$\begingroup\$ Node 1 and 3, node 2 and 4 same but how to proceed further? \$\endgroup\$ Feb 9, 2018 at 17:59
  • \$\begingroup\$ What is the benefit of finding independent nodes? \$\endgroup\$ Feb 9, 2018 at 17:59
  • \$\begingroup\$ @KanwaljitSingh Once you realize that Node 1 and Node 3 collapse to a single node, then you should see that R1 & R2 are in parallel. And the junction point of R1 & R2 is the same as the "-" end of the battery. And the collapsed Node 1, Node 3 is the "+" end of the battery. \$\endgroup\$
    – glen_geek
    Feb 9, 2018 at 18:17
