Here, in this question, I am referring to 3 stage Lin topology amplifier (differential stage - voltage amplification stage - output power stage + negative feedback).
I am wondering about portion of negative feedback being fed from the output to T3 via resistor network.
Here, in this case, voltage gain equals Av = Rf1/Rf2 + 1 = 23. So, I am wondering if the difference in amplitudes between two base-to-emitter voltages of TR2 and TR3 is increased if we increase the Rf1? And vice versa if we decrease the resistance of Rf1?
  • \$\begingroup\$ But isn't this difference equal to Vdiff = Vb2 - Vb3 = Vo/Aol ? Where Aol is open loop gain (the amplifier gain without the feedback ) and Vo is an output voltage? \$\endgroup\$
    – G36
    Feb 10, 2018 at 9:52
  • \$\begingroup\$ \$R_{f1},\: R_{f2}, \: C_2\$ form a low pass filter with corner frequency \$\frac{1}{C_2R_{f1}R_{f2}}\$. Low frequency gain is unity, high frequency gain is \$\frac{R_{f2}}{R_{f1}+R_{f2}}\$ \$\endgroup\$
    – Chu
    Feb 10, 2018 at 9:59
  • \$\begingroup\$ @G36 I don't understand what you are trying to say here. \$\endgroup\$
    – MucaGinger
    Feb 10, 2018 at 10:26
  • \$\begingroup\$ If for example output voltage is 1V and the open loop gain is 500V/V the voltage difference between Vb2-Vb3 is equal to 1V/500 = 2mV \$\endgroup\$
    – G36
    Feb 10, 2018 at 10:31
  • \$\begingroup\$ @G36 Okay, this seems true, I guess. \$\endgroup\$
    – MucaGinger
    Feb 10, 2018 at 10:37
The open loop gain of this amplifier is finite so, to drive a bigger output signal for the same input signal, something has to increase and that will be the difference in signal amplitudes between TR2 and TR3 bases.
It won't be much because at 1 kHz (for instance), the open loop gain will be 1,000 to 10,000. With this sort of gain, the base signal difference to drive 10 Vp-p at the output is in the range 1 mV to 10 mV.
So, with a closed-loop gain of 23, to drive 10 Vp-p at the output, the voltage at TR2's base will be 435 mVp-p and the voltage at TR3's base will be 1 to 10 mV lower. If closed-loop gain doubled, there would still be this voltage difference but TR2's input voltage would halve to achieve 10 Vp-p at the output.
  • \$\begingroup\$ But lets say that we leave Rf1 and Rf2 as they are and we increase the input signal amplitude (Vpp) - what increases the output voltage swing of an amplifier? The difference between two bases probably stays unchanged, right? \$\endgroup\$
    – MucaGinger
  • \$\begingroup\$ If you want a bigger output signal then differences between the two base signals MUST be equally bigger for a given open-loop gain. \$\endgroup\$
    Feb 10, 2018 at 10:33
  • \$\begingroup\$ Yes, this seems true indeed. But if we increase input signal amplitude of TR2 then the signal amplitude at the base of TR3 also increases - which points to the fact that difference between two base voltage amplitudes stays unchanged? \$\endgroup\$
    – MucaGinger
  • \$\begingroup\$ Not quite - if the TR2 base signal doubles you don't quite get double the output signal amplitude - that small difference in what you get (versus what you expected) drives the "system" to produce maybe a 2 mV to 20 mV base signal difference. \$\endgroup\$
    Feb 10, 2018 at 10:42
    \$\begingroup\$ Correct - the output falls-short by a small amount in order to drive a bigger difference voltage between the bases for a given open-loop gain. \$\endgroup\$
    Feb 10, 2018 at 11:04
