Most of us recognize the graph of \$I_C\$ against \$V_{CE}\$ for different base currents (\$I_B\$): -
And, ideally (as we are taught and believe) we would prefer the "constant current" part of the graph to be as flat as possible but, if we had a free-hand in choosing the "perfect" characteristic (irrespective of whether it could be manufactured or not), would we choose a different shape to the plots above?
I'm only thinking about a linear class A single output transistor audio amplifier.
  • \$\begingroup\$ "linear amplifier", are you talking about class A or class AB? Maybe it doesn't matter.. but it would be nice if we both had the same topology in both of our heads. \$\endgroup\$ Feb 10, 2018 at 15:36
    \$\begingroup\$ @HarrySvensson To make it less-complex I mean a class A output stage with a single output transistor. If this restricts answers then I might open it to push-pull class A. \$\endgroup\$
    Feb 10, 2018 at 15:41
    \$\begingroup\$ Texas instruments has marketed a few transistors (example OPA660). Seems the image that is to be implanted in our heads is to think of it as an "ideal" 3-terminal amplifier like a transistor. \$\endgroup\$
    – glen_geek
    Feb 10, 2018 at 15:56
    \$\begingroup\$ @mkeith if you have good reason to take it beyond that then maybe it's worth a shot. I'm trying to avoind me soliciting opinions and already the question is a bit falling into that area. \$\endgroup\$
    Feb 10, 2018 at 16:10
    \$\begingroup\$ Just read this. When I think of a perfect amplifier I think of four kinds of 4-terminal black box blocks with two input nodes and two output nodes: vccs, vcvs, cccs, and ccvs; each with a perfectly constant factor (with appropriate units) relating input to output that doesn't vary over temperature or time or input signal magnitude or output signal magnitude or whether it is Tuesday, or not. Are we talking only about 3-terminal devices? By the way, not just flat curves are desired in your chart. But also uniformly spaced vertically, whether \$I_B\$ or \$V_{BE}\$ curves. \$\endgroup\$
    – jonk
    Feb 10, 2018 at 18:44
from: http://www.ti.com/lit/an/sboa117a/sboa117a.pdf
Meet the transconductor (aka operational transconductance amplifier), which has the following (alas unphysical) Vce/Ic characteristic (forgive the awful mspaint job).
Available as the OPA861. Sort of.
EDIT:
When you learn about BJTs, you learn the hybrid-pi small signal model:
This is the large signal model of the transconductor.
  • \$\begingroup\$ Interesting find. I wasn't aware of this device. One thought about your picture - shouldn't it only be valid for top right and bottom left quadrants? \$\endgroup\$
    Feb 10, 2018 at 17:18
    \$\begingroup\$ @Andyaka No, which is why the transconductor is entirely unphysical, and why the OPA861 has V+/V-. \$\endgroup\$
    – τεκ
    Feb 10, 2018 at 17:31
    \$\begingroup\$ Note that these OPAxxx devices show emitter arrows going both ways. The biasing of these is very unconventional compared with a NPN or PNP transistor in linear service. It actually fits Andy's vision of a "linear" transistor. Its "collector" and "emitter" current can flow both ways. \$\endgroup\$
    – glen_geek
    Feb 10, 2018 at 17:35
  • \$\begingroup\$ @glen_geek very cool indeed. \$\endgroup\$
    Feb 10, 2018 at 17:37
  • \$\begingroup\$ I had a quick look at the TI datasheet. Most of the examples seem to be missing a power source. Apply a voltage at B and current flows out of E and C as if there is a secret battery in there. Can anyone elucidate me what is going on? \$\endgroup\$
    – Transistor
    Feb 10, 2018 at 19:58
Plan on linearizing the bipolar transistor with an unbypassed Re resistor. With 260 milliVolts across the Re, your distortion drops 10:1 (run thru the Taylor Series math, with an additional "stiffening element"). With 2.6 volts across the Re, your distortion drops 100:1.
