I'm developing a type of enclosure that provides EMR shielding. It's constructed of two layers of shielding material. I don't have access to professional test equipment, so my dynamic range is limited. Therefore, I'm only able to measure the attenuation of a single layer of material to any degree of confidence. With two layers, the shielded signal strength is at or below the noise floor. Is there a formula for estimating overall attenuation given two layers of material of known attenuation?
    \$\begingroup\$ Down load a student edition of quickfield (or similar) and simulate it. It utterly depends on frequency of course; low frequencies can pass virtually unhindered as a magnetic field. \$\endgroup\$ – Andy aka Feb 11 '18 at 16:25
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
