I am not aware of drawing more than 1A over PCB traces. We are planning to use ACS712 hall effect current sensor linked below:
https://www.amazon.in/KitsGuru-KG134-ACs712-Current-Arduino/dp/B00YY3UK6S
Can anyone help with the width and depth of the traces for such higher currents?
How far should I place other components including microcontroller?
Should I have heat sink or such arrangements?
Or should I solder copper wire with 5mm thickness to connectors and place sensor module above it?
Thanks in Advance
    \$\begingroup\$ Copper track thickness calculators are available on the internet. \$\endgroup\$ – Andy aka Feb 12 '18 at 10:44
  • \$\begingroup\$ Hello @Andyaka thanks for the reply. I've seen one of the calculator over here. 4pcb.com/trace-width-calculator.html \$\endgroup\$ – Abhishek Parikh Feb 12 '18 at 10:48
  • \$\begingroup\$ That uses ipc-2221 which is opsolete for amperage. Find one that uses ipc-2152 \$\endgroup\$ – JonRB Feb 12 '18 at 10:56
