I have been coming across so-called "band switching diodes" recently, but I can't figure out what they actually are. Is this some type of RF switching PIN diode?
I came across these while I was searching for a cheap alternative to step recovery diodes. Someone recommended using the BA682, which is a band switching diode.
BA682 link
  • \$\begingroup\$ Have you had a look at that datasheet and the "typical applications"? \$\endgroup\$
    – PlasmaHH
    Commented Feb 12, 2018 at 15:37
  • \$\begingroup\$ arrl.org/files/file/Technology/tis/info/pdf/9101024.pdf \$\endgroup\$ Commented Feb 12, 2018 at 15:41
  • \$\begingroup\$ Yeah, it says "band switching". So is it a PIN diode then? Why do I keep finding them listed as Standard diodes on Digikey? \$\endgroup\$ Commented Feb 12, 2018 at 15:43
  • \$\begingroup\$ @ColinMarcus: Its not a pin diode, it would say so. It is just a standard switching diode like 1n4148 or 1n914 or so \$\endgroup\$
    – PlasmaHH
    Commented Feb 12, 2018 at 15:45
Planar silicon diode, specified for this application (dynamic resistance) and made with particularly low capacitance (and relatively high forward drop) compared to a jellybean switching diode.
