I have a code on Arduino to read the data from MPU9255 with no libraries, using it direct through I2C. I am trying to do the same on Keil uVision with Bluepill, just to learn how to use I2C with HAL Drivers.
I don't know What I am doing wrong, here is the code:
uint8_t adressMPU = 0x68;
uint8_t i2cData;
uint8_t* receive_buffer = 0;
i2cData = 0x6B;
HAL_I2C_Master_Transmit(&hi2c1, adressMPU, &i2cData, 1, 100 );  //Starts MPU
HAL_I2C_Master_Transmit(&hi2c1, adressMPU, 0, 1, 100 );
while (1)
    i2cData = 0x43; //adress of the register to read Accelerometer x axis
    HAL_I2C_Master_Transmit(&hi2c1, adressMPU, &i2cData, 1, 100 ); //set the register address
    HAL_I2C_Master_Receive(&hi2c1, adressMPU, receive_buffer, 2, 100); request 2 bytes from the register
    HAL_UART_Transmit(&huart1,receive_buffer,sizeof(receive_buffer),100); // send it to serial port
    HAL_Delay(500);
My code in Arduino that is working:
Wire.begin();                 //inicia I2C
Wire.beginTransmission(MPU);  //Inicia transmissão para o endereço do MPU
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
Wire.beginTransmission(MPU);      //transmite
Wire.write(0x43);                 // Endereço registrador do Gyro
Wire.endTransmission(false);     //Finaliza transmissão
Wire.requestFrom(MPU,6,true);   //requisita 6 bytes
mediaGyroX += Wire.read()<<8|Wire.read();  //GYRO EIXO X
Surely I am doing something wrong, but I can't see the error. Can somebody help me?
  • \$\begingroup\$ You probably need to send the 0x6B followed by 0x00 in a single HAL_I2C_Master_Transmit() call. Something like uint8_t i2cData[2] = {0x6B, 0x00}; HAL_I2C_Master_Transmit(&hi2c1, adressMPU, &i2cData, 2, 100 ); \$\endgroup\$ – brhans Feb 12 '18 at 20:54
  • \$\begingroup\$ I have tried, but does not work \$\endgroup\$ – Vinícius Jean Ferreira Feb 12 '18 at 21:03
For STM32 HAL define the slave address as uint8_t adressMPU = (0x68<<1);, because if you check the register description:
in 7 bit addressing mode actually [7:1] bits of the I2C CR2 register are used but HAL sets the address field as follows:
tmpreg |= (uint32_t)(((uint32_t)DevAddress & I2C_CR2_SADD) | (((uint32_t)Size << 16 ) & I2C_CR2_NBYTES) | \
            (uint32_t)Mode | (uint32_t)Request);
/* update CR2 register */
hi2c->Instance->CR2 = tmpreg;
(I2C_CR2_SADD is 0x3FF which actually just masks the first 10 bits.) So the point is that HAL will set the 7 bit address mistakenly on [6:0] bits of the register if you do not shift to left by one manually.
  • \$\begingroup\$ Thanks, now I can see the mistake! I am receiving garbage ow on the bus, I will try to figure out why \$\endgroup\$ – Vinícius Jean Ferreira Feb 12 '18 at 22:28
  • \$\begingroup\$ @VincíciusJeanFerreira a logic analyzer can be useful also this HAL code is not from the latest version so you should check the actual one in your project. Just to be sure. \$\endgroup\$ – Bence Kaulics Feb 12 '18 at 22:45
  • \$\begingroup\$ Your receive_buffer logic is wrong that is why you see garbage. It is a pointer to nowhere (no memory allocated) yet you try to receive two bytes with it. And then when sending on serial sizeof(receive_buffer) will return the size of the pointer. Define receive_buffer as uint8_t receive_buffer[2] instead. \$\endgroup\$ – Bence Kaulics Feb 12 '18 at 22:55
  • \$\begingroup\$ I post my new code in the comment below \$\endgroup\$ – Vinícius Jean Ferreira Feb 12 '18 at 23:20
