I have a prototype board for Sigfox and LoRaWAN (915MHz) with spaces to install components for a Pi network on the antenna.
We're using a 0R 0603 SMD resistor in place of the inductor, and no capacitors at the moment. I.e. we have bypassed the Pi network.
I was wondering, is a standard 0603 0R resistor ok for the link or do we need special RF rated resistors even though it's 0R?
Virtually all thin film 0603 resistors will be fine. Here is a table of model parameters taken from real resistor measurements made by Vishay: -
As you can see, capacitance is tens of femto farads and inductance is easily sub 1 nH. Table taken from here.
  • \$\begingroup\$ Thanks that’s great info. FYI I was wondering if the resistor could be attenuating our signal. Turns out the u.fl socket was soldered backwards making the RF path open circuit! \$\endgroup\$
    – Michael
    Feb 14, 2018 at 11:19
  • \$\begingroup\$ Nice find!!!!!! \$\endgroup\$
    Feb 14, 2018 at 11:28
  • \$\begingroup\$ The study is specifically about thin film resistors. Would thick film resistors give significantly different values? \$\endgroup\$
    – pfabri
    Dec 9, 2020 at 17:55
  • \$\begingroup\$ Why don’t you formalise that into a site question @pfabri \$\endgroup\$
    Dec 9, 2020 at 18:02
  • \$\begingroup\$ @Andyaka Didn't think it was worth it. I thought asking this (imho) highly-related question here was a better strategy. \$\endgroup\$
    – pfabri
    Dec 14, 2020 at 14:43
