I want to control the gate or base of a transistor by either a MCU gpio or push button. Can link gate to both the push button and MCU so I can choose which to use. What is best way to do this?
    \$\begingroup\$ How is the transistor configured? Specifically, for the MCU? \$\endgroup\$
    – Trevor_G
    Feb 13, 2018 at 17:23
  • \$\begingroup\$ As a simple switch that turns on an led. But want to be able manually turn led on with push button or with MCU. Just wanted to know best way of connecting that will have no errors \$\endgroup\$
    – JOHNDOE
    Feb 13, 2018 at 17:26
You can or them into the base like this...
Or simply put the switch in parallel with the transistor.
  • \$\begingroup\$ Thanks only thought of the first solution you gave. Never thought of the parallel setup. Is the diode required \$\endgroup\$
    – JOHNDOE
    Feb 13, 2018 at 17:40
  • \$\begingroup\$ @JOHNDOE yes and no, without the diode when the MCU is pulling low it will steel some of the current from the switch so the LED will not be so bright. Whether that matters to you I have no idea ;) If you are using a MOSFET the gate voltage would be half so it may not turn on at all. \$\endgroup\$
    – Trevor_G
    Feb 13, 2018 at 17:45
  • \$\begingroup\$ @JOHNDOE you would not need the diode if you configured the IO pin as open-source. That is.. pulls high when active, high-impedance when not. \$\endgroup\$
    – Trevor_G
    Feb 13, 2018 at 17:53
  • \$\begingroup\$ Ok. Is it better to use a bjt or a mosfet \$\endgroup\$
    – JOHNDOE
    Feb 13, 2018 at 17:57
  • \$\begingroup\$ @JOHNDOE mosfet wastes less current... \$\endgroup\$
    – Trevor_G
    Feb 13, 2018 at 17:58
