I want to use (probably) four ultrasonic sensors HC-SR04. These use a trigger pin and echo pin.
For the echo pins, I want to connect them to a timer with 'Combined Channels PWM Input on CH1', and the Input Trigger set to TI1FP1, so it is able to automatically time the high time of an echo.
However, since I don't want to use 4 timers, I want to interconnect all echo pins (and trigger the trigger pins of the sensors one by one).
Would this work, or is it not adviced to 'set' a signal to an echo pin when another echo pins becomes high?
Or should I use an IC with logical ORs? or is there a better/easier way?
I got it by someone and he doesn't know the source, so I don't have a datasheet, this is something similar: Information
    \$\begingroup\$ Why not use a multiplexer IC? \$\endgroup\$ – Marshall Eubanks Feb 14 '18 at 23:05
  • \$\begingroup\$ @MarshallEubanks I have to check what that does (limited electronic knowledge). \$\endgroup\$ – Michel Keijzers Feb 14 '18 at 23:08
    \$\begingroup\$ Add the link to the datasheet so we're all using the same one and we don't all have to search for it. \$\endgroup\$ – Transistor Feb 14 '18 at 23:09
    \$\begingroup\$ Depends how the echo pins are wired inside the sensor. \$\endgroup\$ – user253751 Feb 14 '18 at 23:47
  • \$\begingroup\$ @Transistor I don't have a datasheet, updated my answer with some information (last paragraph). \$\endgroup\$ – Michel Keijzers Feb 15 '18 at 10:17
No, those sensors use a TTL level output signal for echo, so you'll have use an or gate or diodes plus a resistor to implement an or gate. You can drive all the triggers with a single output, although you won't be able to tell which sensor each echo comes from and multiple echo pulses that overlap will appear as a single long pulse.
  • \$\begingroup\$ Sounds like an easy solution, depending on how many I want to use (4 in principle). \$\endgroup\$ – Michel Keijzers Feb 15 '18 at 10:18
  • \$\begingroup\$ Just in case, I check for multiplexers (probably CD4051BE will do), but this is an elegant sultino for if I don't want to use an IC. \$\endgroup\$ – Michel Keijzers Feb 15 '18 at 11:33
The Echo pin is a TTL output1, according to the datasheet for the HC-SR04. Don't wire the Echo outputs together directly. If one output is in a high state and another output is in a low state and they are connected together, then one of the outputs can burn.
Instead, combine the outputs using an OR gate IC.
1 If it were open-collector or an open-drain output, you could create a wired OR with a pull-up resistor.
