I am trying to come up with a circuit using logic gates to drive a seven segment display.
I have a circuit with a BCD output (A, B, C, D) and need to convert this so that when any one of nine buttons are pushed, they produce a number.
The circuit needs to display a 0 when nothing is pressed. However, when buttons 1 - 9 are presesed it needs to display 7, 4, 8, 0, 5, 6, 8, 8, 9, respectively.
I have produced truth tables and k-maps, which all seem to be correct. But, it does not seem to be working at all. I get random numbers and a couple of odd displays of random elements on the display (not numbers or letters).
If anyone can point me in the right direction, or give me some advice, I would be eternally grateful!
  • \$\begingroup\$ I've made the circuit easier to read. If I've screwed up then sorry. \$\endgroup\$ – Andy aka Feb 15 '18 at 12:51
It's not clear why you're going via BCD. Just create the combinational logic directly.
Figure 1. Pressing a switch turns on the segments connected by small signal diodes.
  • \$\begingroup\$ I am converting from BCD... \$\endgroup\$ – Nick H Feb 15 '18 at 12:58
  • \$\begingroup\$ @NickH yes your circuit shows this but why bother - interface directly with the buttons and cut-out the clutter. \$\endgroup\$ – Andy aka Feb 15 '18 at 13:01
To be honest: I can't take the time debugging your circuit. I just wanted to point out that I would have approached the functionality different.
Use a 7447 decoder and re-arrange the button order so button 1 is connected to input 7, button 2 to 4 etc. For number 8 put two button in parallel.
  • \$\begingroup\$ Yeah, I have initially used a 7447N, and this worked perfectly for what I initially needed, now I want to remove the 7447N and use just logic gates to produce the desired result to depen my understanding. Thank you for the input though. \$\endgroup\$ – Nick H Feb 15 '18 at 12:55
Most likely the issue would be caused if aren't accounting for the fact that the buttons and LEDs are inverted.
When the button is pressed, the input value will be a 0.
When the output is a 1, the LED segment will be off.
  • \$\begingroup\$ That was something that occured to me after quite some time... I have accounted for that, and changed the circuit accordingly. Accounting for it, allowed me to get close to acheiving what I want, but still "no cigar". \$\endgroup\$ – Nick H Feb 15 '18 at 12:58
