Which is the best way to connect broken pieces of solar cell to equal 1 solar cell? Below are 3 configurations of how I might use solder to build a cell. Does the configuration make a difference?
  • \$\begingroup\$ mending broken glass? PV's are current sources with Voc. What are the parameters of each if not same then put parallel, P, if matched then series ,S is ok ... or matrix xSyP of matched current parallel groups in series. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 15 '18 at 16:59
    \$\begingroup\$ ensure each pc. has no shorts.. measure Voc with bright light. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 15 '18 at 17:04
    \$\begingroup\$ first probe under light, connecting is a problem , I cant see, maybe 99% silver epoxy.. probably not fixable. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Feb 15 '18 at 17:07
    \$\begingroup\$ @Andyaka I'm poor \$\endgroup\$ – user103579 Feb 15 '18 at 17:26
    \$\begingroup\$ They already have a type of panel made of bits of solar. Just doing this to save on power for the house. \$\endgroup\$ – user103579 Feb 15 '18 at 17:28
First the easy answer then the difficult one.
  1. Easy answer buy very low cost cells from China. Less than $1 us including shipping to my house in the US. Here's a link
  2. Tough Answer: To connect the pieces you need to..... find which of the electrodes are P and N junctions. This is not easy with pieces. If you can figure it out you need to connect all the wire traces of the P junctions and all the wire junctions of the N junctions. Here's a link to a picture of the back of a cell with positive and negative terminals.
Not sure this is clear, but it's very difficult after the cells are broken.
