Background
I have a power inverter in my car that I installed about 4 months ago. I bolted the ground on it to the ground terminal connector of my car battery and the + to the positive side of it. Fast forward to present, my ground on my car is corroded significantly and the nut and bolt on it have corroded so badly that the nut has puffed and the terminal is orange (both were silver instead of that poopy color). Ill add a picture of it.corrosion of connector and terminal connector
One part of the problem was that these terminal connectors are junk, ground one never really clamped on the battery that well (decent but could be bumped off with your hand no matter how tight you tightened it) and I have replaced that old terminal with one like this ( https://www.electricalhub.com/generic--battery-terminal-top-post-1 ) as my car would no longer start with the old one and was just giving me way too many problems.
Capacitor / Battery situation question
With that said I am trying to figure out how best to handle the inverter now that I have replaced the battery terminal. One problem I had with it outside of the corrosion thing is that when I start my car, the inverter would freak out and start beaping at me until I turned the inverter off and then back on after having started my car. I am assuming that it either doesn't like the electrical noise that occurs from starting my car, or the voltage drop from staring my car would drop the inverter low enough that it would not work until it was turned off and then back on as some kind of annoying (to me) safety feature... The inverter works fine outside of when i start the car however.
I was thinking about either getting a small motorcycle battery that would act as a buffer between the car battery and the inverter to reduce noise/ voltage drop or getting a large capacitor instead. Both I would put closer the the inverter as I have about a 7-8 foot run from the battery to the inverter.
[Frame]--[Battery]--------[Inverter]
[Frame]--[Battery]------[2nd Bat or Capacitor]--[Inverter]
1 "-" is equal to 1 foot of wire
if a capacitor is the better way to go, can you please link me to one? the best I can find is ones made for 440V and I feel like that would be overkill. I don't really know how to differentiate capacitors so a dummed down explanation would be awesome since I am not sure how to make google give me an explanation i could follow since the ones I was looking at had stuff like 40-5 and 60-7.5 in the description which threw me for a loop
Welcome to the world of bad connections.
Corrosion will happen any time metals that are different touch. Add in current, arcing and all the heat it brings heat you'll start seeing what you see. Fixing the battery connection to one that makes good contact and you might see a huge difference.
You haven't stated the type of car, it looks like the battery is in the trunk, judging by the vent hose and tire. That would diminish the harsh environment of open engine bays. Pointing more towards poor connections causing heat, speeding up corrosion. as corrosion increases, electrical resistance builds up causing more heat. Add increased draw from the inverter and you are where you are now.
If your using it a lot, you might want to look into a second full sized battery, with accompanying isolation. your amp won;t kill your main battery and you can jump start yourself.
  • \$\begingroup\$ Chevy Cobalt 08 \$\endgroup\$
    – Tab Carmel
    Commented Feb 16, 2018 at 5:15
All you need is one good car battery and good connectors with adequate CCA.
Contact material and condition matters as it has to be compatible and a gas-tight seal. If the clamp cannot be tightened then it has been stretched and cannot be tightened , then it must be replaced. Contact resistance must not drop in voltage with 600A or whatever during engine start. CA rating is standardized as the max current when the battery drops from 12.5 to 7.5V which is essentially ESR so that 500A CA is 5V drop over 500A = 10 mOhm . The battery terminal ought to be less than a few % of this. If not then it is not a gas-tight seal and has been oxided and will continue to oxidize and corrode from occasional sulphuric acid outgassing from the battery. Also galvanic corrosion will be accelerated.
Typically battery connectors are lead-alloy to lead-alloy terminals or copper plated japan-steel bands found in many cars. Vaseline coating works well to prevent copper sulphate external corrosion after tight connection.
My car cuts out accessories during engine start, yours should too and your direct connection bypassed this important process to prevent unnecessary battery loading during engine start as well as perventing under-voltage to the inverter which goes bizerk.
So your direct connection is a problem. Adding a spare battery with an isolator may be what you need or better an power relay that cuts out the inverter or the cig. lighter connection if start disable-switched.
Using a capacitor may help with RF but will not prevent undervoltage as caps may be big enough to start a snowmobile but not a car or truck from dropping to 7.5V
Although unless your engine is <-30'V it should take the full CCA rating and the starter RPM sound will tell you the voltage by the frequency of the sound.
I could prove what I say with RC time constants and supercap Farads which are much smaller than battery xx kilofarads, but take my word for it, a good battery shud do the job if you want your inverter draw current during engine start.
  • \$\begingroup\$ I wasn't planing to isolate the 2nd battery, I was just going to keep them in parallel thinking that it wouldn't have any ill affects. I originally installed it with a ring that goes around the terminal and the wire went into a connector off the ring, but the ring did the same thing. Since the run is about 7 feet and takes 12V to 120V, I was concerned that the draw from something like a laptop would be too high for a relay or switch since a switch would just have small connectors and would corrode up over time from heat since it draws so much technically converting from 12v to 120v. \$\endgroup\$
    – Tab Carmel
    Commented Feb 16, 2018 at 5:24
  • \$\begingroup\$ You don't think adding a relay switch to the will cause more trouble? I think that it requires 12ga or 10ga to run the inverter at max capacity. Someone mentioned the inverter will draw all the time which could cause the corrosion to speed up and suggested a switch for that reason, but I want to avoid having to open my trunk every time I want 120v power. \$\endgroup\$
    – Tab Carmel
    Commented Feb 16, 2018 at 5:30
  • \$\begingroup\$ the thing that blows my mind is how quickly it corroded, it makes me think that it is pulling alot all the time with that bad connector to end up like that over such a short duration. Could that have anything to do with the length of the run? My father told me that the gauge was way too small for that long of a run originally and we beefed it up to 12ga or 10 ga i believe, which he thought would fix it. I originally did it in 14ga I believe. \$\endgroup\$
    – Tab Carmel
    Commented Feb 16, 2018 at 5:33
  • \$\begingroup\$ the factory terminals were not lead, nor were they copper, thats for sure. they looked like steel, they were a silver color from factory. My replacement was lead. \$\endgroup\$
    – Tab Carmel
    Commented Feb 16, 2018 at 5:38
  • \$\begingroup\$ hmm seems like a good combination for galvanic corrosion \$\endgroup\$
    – D.A.S.
    Commented Feb 16, 2018 at 5:55
