I have a circuit that normally runs at 3-5v and then when triggered, it gets pulled to ground (around .1-2 mv leakage). I want to use this to trigger a relay to close a different low voltage circuit. Can I use the "Sainsmart DC 5V Relay Module for Arduino PIC ARM DSP AVR MSP430 TTL Logic" board to achieve this?
{With my specified input} can I use the "Sainsmart DC 5V Relay Module for Arduino PIC ARM DSP AVR MSP430 TTL Logic" board
Yes. A low level input WILL operate this OK as long as it can provide enough current to operate the optocoupler. See below
Please provide web links when asking about specific products.
Your product is here
The circuit diagram is shown below.
Sainsmart may be able to advise how much current is needed.
10 mA is usually enough - occasionally more is needed and sometimes much less.
R14 may need to be changed.
The Vcc changed would ideally be the same voltage that you say is 3-5V so that there are no pronblems when the input is high.
