I'm trying to design a flyback converter to power my stuffs, I need about 3 A of current at 24 V.
At first I though this was straightforward. However, after reading "Design Guidelines for Off-line Flyback Converters"(AN4137) of Onsemi, I have found that it isn't that easy. Capacitors have max ripple current specification which mean I could risk blowing them if I just use a single of them. Therefore I think I should use some of them in parallel to distribute the ripple current (I think so). According to the appnote,
I calculated the output peak voltage ( about 88 V in my design) so using 100 V rated caps should be fine. Another problem arises : I don't have much 100V-or-larger electrolytic capacitors.
After thinking awhile, I remembered that there is someone who uses "capacitance multiplier" in there power supply design.
Will it do the trick ? Instead of going to the store and buying some caps, should I use it ?
By the way, please help me correct grammar error, I am aan English learner, not a native.
Thanks !
