45
I've been looking at some microcontrollers and I've seen they've got some "weird" minimum operating temperatures, like -25 degrees or -10 degrees etc. But I can't really understand why there is a minimum, a maximum I do understand because everything melts down and breaks, the resistance increases making the signals too weak. But when you go to the cold side. Everything kind of gets better and better, the resistance gets reduced, everything gets more stable. But yet... the minimum operational temperature is -25 degrees... Why is it not 0 Kelvin?
Because I was thinking about the mars-rover and other satellites, when they are behind the sun they are operating at nearly 0-50 kelvin, the mars-rover... according to wiki it gets as cold as −87 °C (−125 °F). And this is still very much more cold than -25 degrees.
So, can anyone please explain to me why microcontrollers do have minimum operational temperature? The more thorough the better.
    \$\begingroup\$ -25 is probably not cold enough for space depends on the vehicle, etc. Also I doubt your microcontroller is rad hard so it wouldnt last very long anyway. But think about a car stereo in alaska or cananda or some other device that might get a cold soak but is expected to still work. The die will warm up fast but the air, etc around it will take a while. commercial parts will latch up if they get too cold and then melt down if you dont detect the current draw and turn them off. \$\endgroup\$
    – old_timer
    Jul 19, 2012 at 20:02
44
2nd Edit! Modified my answer about semi-conductors based on jk's answer below, read the history if you want to see the wrong bits I modified!
Everything gets weird within certain limits. I mean, sure, the resistance improves in conductors but it increases in semi-conductors, and that change effects how the IC works. Remember that the way that transistors work on the basis that you can modify their resistance, and if the temperature drops so low that you can no longer decrease their resistance, you've got an issue! Imagine that suddenly your semi-conductor essentially became a resistor... how do you control it? It no longer behaves the same way! Now I'm a bit confused at where you're getting the -25°C, as the industrial/military spec should put it at -40°C for the minimum operating temp.
But for the space question, I can answer that as I work in a space lab! In general you have three thermal concerns in space:
1) In space, you only radiate heat. Radiation is a terrible way to get rid of heat. In the atmosphere, you conduct heat into the air around you which makes cooling a lot easier. So in space, you have to put big heatsinks on to get the heat into larger radiative surfaces.
2) If you have a component which doesn't generate heat, then space is happy to let you get really friggin' cold! In general, what you do is you have active heating elements to keep components which don't generate more heat than they radiate but have thermal limits.
3) Heat swings are common because you will exit and re-enter the sun's rays. Thus you need to have active thermal management where you have a big heatsink which can radiate heat when it's hot, and a heater for when it's not.
You can also get extended temperature range devices which go lower and higher, but there's pretty much always a limit. Some of them are for where the cold temperature will crack the die because the metal will shrink more than the plastic (or vice versa) which is why they list limits for storage as well!
The limit is mostly in materials. You also tend to get space-rated chips made out of ceramic for the packaging, which can also raise or lower the thermal limits.
Anyway, I hope that explains it for you. I can try and answer any other questions, but I'll admit the physics of low-temperature semiconductors is not my forte!
1st Edit:
Here's a link to a wikipedia entry about the idea that at lower temperatures there are fewer electrons which are excited enough to generate a current flow through a semiconductor lattice. This should give you a good idea of why the resistance becomes higher, and why 0 Kelvin would have never been an option.
    \$\begingroup\$ Interesting read! I think indeed the bond wires will break in plastic packages due to shrinkage. \$\endgroup\$
    – jippie
    Jul 13, 2012 at 7:49
  • \$\begingroup\$ CTE stress on gold bondwire is one factor below freezing Moisture expansion AT freezing if any ingress.. will shear it. \$\endgroup\$ Jul 13, 2012 at 21:17
  • \$\begingroup\$ Its not the temperature that will kill IC's in outer space, it's the Gamma radiation you have to worry about. \$\endgroup\$ Jul 14, 2012 at 1:32
  • 4
    \$\begingroup\$ There's all sorts of things that will kill ICs in space. Latch-ups due to radiation are definitely a concern, but they've been doing some testing and the tiny manufacturing size on modern transistors have made them way more resilient than old circuits (oddly enough). But either way, I'm not sure that you can single out any one thing about the space environment and say "THAT! That's the thing that will make it hard." It's all difficult (this isn't even mentioning outgassing concerns which make zinc coated connectors a terrible choice), and it's all out to get you up there. Space is hard! \$\endgroup\$
    – Kit Scuzz
    Jul 14, 2012 at 3:44
    \$\begingroup\$ In an atmosphere, not only do you conduct heat into the air, but you also use convection to carry that hot air away from the heat source. Two cooling methods for the price of one... which happens to be free. \$\endgroup\$
    – MBraedley
    Jul 17, 2012 at 19:41
14
Kit's answer is dead right about components in space, but I thought I'd expand a bit on semiconductors vs conductors (very loosely without the maths).
Conductors resistance decreases with a drop in temperature. This is loosely, because the resistance comes from the free flowing electrons being slowed down by vibrations in the crystal lattice they are flowing through. Lower the temperature means less the vibrations.
Resistance of semi-conductors increases with a drop in temperature. This is loosely, because they don't have free electron to carry charge at low temperatures in the first place. As they are warmed they get more charge carriers and this out weighs extra resistance from increased vibration in the structure.
Lastly, superconductors rely on strange quantum phenomenon. Either at very very cold temperatures and/or by having their free electrons confined to a 2d film rather than a 3d solid allowing the physics to get weirder.
  • \$\begingroup\$ does this imply that semiconductor-less electronics are generally going to be more reliable than semiconductor electronics in extremely low temperature? \$\endgroup\$
    – Lie Ryan
    Jul 13, 2012 at 11:26
    \$\begingroup\$ @LieRyan Would that not depend on what you use instead? For example, vacuum tubes working in an extremely low temperature environment would seem to me to have a high risk of failure due to the extreme temperature difference between the inside (filaments) and the ambient environment, unless other measures are taken. \$\endgroup\$
    – user
    Jul 13, 2012 at 11:33
  • \$\begingroup\$ Yeah, it's been a while since I took device physics... Thanks for the correction! \$\endgroup\$
    – Kit Scuzz
    Jul 13, 2012 at 14:09
added Aerospace Vehicle Systems Institute (AVSI) has conducted research into this question.
"Accurate Quantitative Physics-of-Failure Approach to Integrated Circuit Reliability" Their conclusions are based on physics and Root cause analysis especially since feature sizes have shrunk orders of magnitude over that last 30 years.
  1. ElectroMigration (EM) (contamination of semiconductor from slow leakage of metallic ions)
  2. Time Dependent Dielectric Breakdown (TDDB) or the slow tunnelling of a conductor path thru the oxide insulator from weak fields ( and gamma radiation )
  3. Hot Carrier Injection (HCI), when a concentration of holes jumps a dielectric barrier in charge traps used by memory cells to permanently alter memory state caused by radiation gradually eroding the margin till failure.
  4. Negative Bias Temperature Instability (NBTI) NBTI stresses, which shift PMOS transistor threshold voltages, have become more prominent as transistor geometries reach 90 nm and below and aggravated by static long duration charge traps enough to cause failure.
These FOUR REASONS above are the most common now with deep space IC's as well as consumer IC's. Space has more radiation and environmental stress factors. Moore's Law has also accelerated these new failure modes.
Historically, the most common generic reason for old technology IC's were limited in temperature range have to due with operating with packaging & environmental stress.
Thermal shock, condensing and rapid evaporation as well as analog effects of thermal drift Consumer IC are limited 0~85'C in plastic cases for this very reason. It is not a perfect seal and moisture ingress is possible. But even space hardened glass passivated ceramic IC's have thermal limits. In addition to the moisture issues stated below, read the most recent confirmed issues above.
End edit
If there is enough moisture molecules over time and it freezes and cracks the substrate it fails.. If it is working ok in a frozen state with frozen molecules of moisture and then thaws and causes corrosion or leakage and fails. It's your fault. Some plastic seals are slightly better and self-heating prevents some from freezing below certain temps this also reduces migration of moisture.
At the high end , popcorm effect causes moisture to blow chips and Black epoxy grade has improved significantly over the last 40 years due to Sumitomo. Clear Epoxy is not as good and used in some LED cases or IR devices. So LED's must stay packed dry before soldering. Modern designs of large LED engines without the gold whisker wirebonds are rated to a certain RH @ Temp indefinitely, while the rest are a risk after a few days of open exposure to high RH. Really it's a valid risk and as bad as wounding them ESD, except it shears the gold wirebond.
This is why all space or military temp range parts tend to be ceramic with glass coating on leads and consumer parts are rated to 0'C.
Any exceptions such as Industrial and Military temp range are due to tighter specs needed for Military over a wider temp range than Industrial but they both function over a wide range just not guaranteed analog specs.
CMOS runs faster cold than hot. TTL funs faster hot than cold and junction temps drop to dissipate less heat. I have tested HDD 8" disk drives over a bag of dry ice < -40'C after an hour just for the military to prove it works, but no guarantees with condensation preventing head-crash.. ( the motor bearings squealed for a few seconds tho.... but passing 0'C from freezing going up... that's a humidity risk.
added journal references for proof. The limiting reliability factor that affects the temperature of ALL integrated circuits ( especially large chips such as microcontrollers) is the mechanical packaging more than the function of the semiconductor. THere are hundreds of reliability articles to explain this. There are also articles to explain why there is a variance of low temperature limits. Some are de-rated from -40'C for good reason, and those extended from 0'C may be for bad reasons. Although not explicitly stated that profit is reason, junior engineers mis-apply HALT improperly to extend qualified ranges at risk from misunderstanding the chemical migration and structure stresses that exist. While wiser companies will re-derate with good reasons, which I will support with references below.
1. Hermetically sealed properties are not a digital phenomena.
It is analog and relates to the amount of ingress or moisture leakage atomically creaps into a mechanical package.
enter image description here As stated in above link
  1. "the internal outgassing may induce the formation of water droplet condensation, thus compromising the device performance and even- tually leading to device failure." 2." seals produced were hermetic initially, but tended to fail catas- trophically during prolonged soaking and temperature cycling in saline because of the difference in the CTE between the glass capsule wall (5.5 × 10−6/◦C) and the 90% Pt–10% Ir feedthrough (8.7 × 10–6/◦C). "
  2. " From the nomograph in Fig. 6, it can be seen that at 1.0 atm and 0◦C, the moisture concentration needed for forming water droplets is 6,000 ppm. At levels below this percentage of water vapor, liquid drops will not be able to form. Hence, most materials and sealing processes are selected to keep the internal package environment at or below 5,000 ppm of moisture for the lifetime of the device." However contamination can alter this. enter image description here
I could write a book on this subject, but then so many others have already, so I will merely reference some literature, which will prove my answer is valid.
Keywords with links
    \$\begingroup\$ I don't think this represents the reason that circuits won't work below a certain temperature. Certainly that's why temperature cycling on ICs will end their lives, and why moisture will cause issues during manufacturing, but this isn't what the question was asking... \$\endgroup\$
    – Kit Scuzz
    Jul 14, 2012 at 3:47
  • \$\begingroup\$ Not just during but after. I am only answering your question. Pls see proof added to my Answer. Moisture ingress, stresses, CTE, etc and packaging are the functional limitations of all IC's way before theoretical limits previously discussed. I am trying to remain grounded and relevant. \$\endgroup\$ Jul 14, 2012 at 11:33
  • \$\begingroup\$ I don't deny that your answer is valid and I'm not trying to be mean! (sorry if I'm coming off that way) Moisture ingress during temperature cycling and manufacturing is an issue that can cause a lot of problems. I am trying to say that it is not answering the question asked in this thread, which is "why is there a minimum operating temperature?" \$\endgroup\$
    – Kit Scuzz
    Jul 14, 2012 at 19:02
    \$\begingroup\$ I don't believe that TI's radiation-hardened c6701 processor lists a minimum temperature of -55°C because of moisture concerns. If I have a c6701 in a satellite in GEO orbit where there is no more moisture to be had, it will fail at -70°C because of electrical and mechanical reasons independent of moisture. And I think that the asker was asking more about this type of failure rather than temperature-cycling induced moisture failure (hence the specific question about space systems). \$\endgroup\$
    – Kit Scuzz
    Jul 14, 2012 at 19:05
  • \$\begingroup\$ If you had asked about a specific part, I would have given a specific answer. Since your query was about weird -10'C and other non-std military IC's and generalized question about some micro-processors, I gave the implied generally correct answer. If you want a relevant answer on one p/n, ask a new question. BTW I recall when I paid $500 for a Burr Brown 883B DAC hybrid @12MHz that had X-RAY inspection etc and still had missing codes from digital ground noise from internal binary drivers shifting the reference voltage... FYI \$\endgroup\$ Jul 14, 2012 at 19:11
