I am trying to understand the layout of a DDR4 chip connected to a FPGA. The schematic follows:
I tried to look for datasheets from the memory manufacturer explaining how to properly pull-up or pull-down pins that might be in high-impedance state FPGA side to no avail. There seems to be no material for any decoupling on clock lines either.
I have the following questions:
- How are the pull-up and pull-down resistor values calculated? The majority of them are at 39.2 Ohms. Is the value low as such to not interfere with the signal integrity (parasitic capacitance charging/discharging) under high switch frequencies?
- Why is there a capacitor in series with the pull-up resistors for the clock pins (CK_t and CK_p)?
