I want to measure the frequency of a signal using the digital input pins of the NUCLEO-F767ZI. The signal is sinusoidal with an amplitude of 5 V and a frequency ranging from 100 kHz to around 400 kHz.
1.) First I thought about simply feeding the pure analog signal to the input pin that is 5 V tolerable. I thought about using a serial diode for protection against the negative half cycle and using the internal pull down resistor of the MCU. Then I could generate an interrupt whenever the sinusoidal signal is high enough for the GPIO to recognize it as logical HIGH.
2.) After a bit of research on StackExchange, I also found configurations using opto-isolators: Detecting Zero Crossing of Mains (Sine and Square Wave) The advantage is that it would output a sharp rising edge easily recognizable for the digital input pin, rather than the limited slope steepness of a sine wave.
3.) Since the signal does not have a dangerously high voltage, I could also skip the isolation and use a simple BJT or MOSFET instead. This would also output a sharp rising edge.
Which of the above options would you recommend? And above all: I hope that the parasitic capacitances of the semiconductor devices do not have any effect below 500 kHz, is that right? Or do you have a different and better approach?
Best regards and thanks in advance!
